In the neverending quest to keep my MF35 running
mtnbikerman
05-06-2005 04:59:43
I broke the fuel line running from the T-union at the bleed off line to the fuel filter. The line is welded/cast onto a little doughnut that a bolt goes through into the filter. Are there any work arounds to this line? The dealer is killing me on parts.
Jack in NB
05-07-2005 05:16:59
 Re: In the neverending quest to keep my MF35 runni in reply to mtnbikerman, 05-06-2005 04:59:43
We've used a couple of work-arounds.
The first - if you have enough pipe on each side of the break, use a piece of flexible fuel line slipped over the break and clamped. 3/16 ID, I think. Food grade clear plastic tubing also works, but hardens after a few years.
Second, if the broken stub is too short,drill out the remains, insert a new section (copper works well) and solder it. I make the insert long enough to put on a flex joint where it doesn't interfere with other hardware - usually about midway - and cut the original line to fit.
I've done this with nearly all of the original steel lines. It started with fixes for holes chafed by vibration (neither solder nor Seal-all worked effectively), and these were so easy to re-install (the flexibility allowed VERY easy line-up and no more crossed threads in fuel pump and filters, overflow lines and thermostart!) that I did it with all lines as they were reworked at overhaul.
I think the term for this flex joint is "olive" - at least that's what Lindburg called it when he did this to all lines on the Spirit of St. Louis, to prevent them from cracking from vibration in flight.
Jeff-oh
05-06-2005 09:08:09
In my MF65 parts book, that is a Line assy, leak-off, tee to secondary filter. old PN 189 162 M91 new number 189 522 M91 I know these numbers probally do not help, however, have you contacted a full line MF dealer? I persume you have... is there a replacement part number?
To fix, If you have space and enough line you could get a flaring tool and a coupler and splice it.
Sorry for not haveing a great easy answer, let us know how it works out.
Jeff
mtnbikerman
05-06-2005 18:47:14
 Drilled out the doughnut for the hose and solder i in reply to Jeff-oh, 05-06-2005 09:08:09
Then the other end started leaking and the leak off line to the tee. UGGGGG HHHHH H
Jack in NB
05-08-2005 05:14:31
 Re: Drilled out the doughnut for the hose and sold in reply to mtnbikerman, 05-06-2005 18:47:14
Uh Huh. Those things happen.
Keep going - you'll get it licked! (- or stopped - licking would taste bad..... It's a rainy Sunday morning - couldn't resist!)
And a safety note re my earlier comment about splicing the lines - I forgot to add the caution - just the low pressure lines should be operated on.
NOT the heavy high pressure lines going from the pump to the injectors!
Good luck, and let us know how you make out.
Jack
mtnbikerman
05-06-2005 05:13:57
 Why do I break disco parts? in reply to mtnbikerman, 05-06-2005 04:59:43
What other parts for this thing are discontinued that break often?I thought I was getting a tractor that there were still tons of parts for.
anyways the part no187018M91 is obsolete. Its goes from the tee to the top of the secondary fuel filter any suggestions? Other than be really careful next time
Ray,IN
05-08-2005 23:27:16
 Re: Why do I break disco parts? in reply to mtnbikerman, 05-06-2005 05:13:57
Run a net search for Mf tractor parts. I can't post them because YT deletes my post if I do. Three large business' have nearly everything you'll need.
