JD H hard to start
JohnDeereDude
11-21-2002 17:04:20
I have a 39 hand crank model H. Seems like it it doesnt suck gas into the engine. I have rebuilt the carb. Anyone have any ideas? Thanks for any help.
JRH
11-22-2002 18:40:06
 Re: JD H hard to start in reply to JohnDeereDude, 11-21-2002 17:04:20
Clooney said it all. One thing, let the bowl fill with gas before cranking. A few minutes will do. Sometimes I get anxious and start cranking to soon. If I wait mine usually starts the first turn.
John
brian
11-22-2002 14:47:38
join the club!i had the same thing with mine but but you never said what tank you were running the
gas thuw tell me that.
Clooney
11-21-2002 17:14:06
JohnDeereDude, see the below post on this very subject.
Chris
11-21-2002 17:09:42
Someone is going to disagree but i am going to tell you this anyway. I cleaned the carb on my 39b. It would start after about 7-10 pulls on full choke. Ran perfect just wasnt getting enough fuel when cranking. I had cleaned everything was getting good fuel to carb. I took my dads advice. I knew since it ran so good and eventually started that it could not be much. So i went to autozone and bought a can of carb cleaner that you put in your tank. Ran it and after about two days. I go out put 3/4 choke and it start on the first pull EVERYTIME. Unless im showing someone. I run this tractor almost daily. And that worked for me. Thanks
abe
11-24-2002 19:30:18
 Re: Re: JD H hard to start in reply to Chris, 11-21-2002 17:09:42
42h will not start unless pull/carb/head vlvs/mag/pts/cond/gov&weights/timing/fluch and cleaned tanks/plugs&wires/ crank crank crank no start/put a chain on it pull 1/2 turn of wheels and will sit and run all day/
to save my nerves i use my a & g/if cant remedy this h good bye to it
nice to see i am not alone on this
my dad said it never started good from the day grandpa brought it home new
everything i have mentioned above has been checked over several times/this has been like this
for 15 years.
