John Deere Model 70 Gas- Govenor
POP
05-02-2002 16:02:00
Are the weight dogs aginst the sleeve or aginst the thrust bearing in the govenor? Having trouble setting up linkage from throttle to govenor and from govenor to carb. All help will be appeciated Thanks
Clooney
05-02-2002 17:00:43
 Re: John Deere Model 70 Gas- Govenor in reply to POP, 05-02-2002 16:02:00
~POP, the governor weight levers push against the big shoulder on the sleeve, the thrust bearing is in contact with the fork on the governor lever shaft. ~Mike Aylward posted a good procedure on linkage adjustment (I believe it was to you) & that should cover you on linkage adjustment...
