Re: HEY CLOONEY/60 Shake/Vibration/Knock
Don
11-16-2001 14:18:32
If you are seeing backlash between the crankshaft and the flywheel you have a major problem .Loose flywheels will knock and sound like it's on the clutch side, if it's loose enough could cause a vibration. Also check the clutch driver for proper timeing .Don
