Defect??
RobMD
05-10-2008 11:04:28
Uhm... what defect????
Seriously, all it takes to remove the flywheel COVER is about six quarter inch bolts and the removal of the starter foot pedal.
Very easy...
and Certainly not a defect.
elcajonfarms
05-10-2008 12:56:12
 Re: Defect?? in reply to RobMD, 05-10-2008 11:04:28
I didn't mean to start an argument. I was just comparing some of the earlier electric start B's that had an access panel on the flywheel cover and a detachable steering wheel you could use to hand-start in an emergency. I agree it's safer to have a covered flywheel, and that the cover is easy enough to take off, but what I miss is the ease of hand-cranking!
Mike M
05-10-2008 13:03:02
 Re: Defect?? in reply to elcajonfarms, 05-10-2008 12:56:12
Your 50' model B SHOULD have an access panel to pop out of the middle then you can use an adapter and a steering wheel to turn it over.
Very likely your switch contacts are worn. You may be able to adjust the starter push rod ( it is made to adjust ) and maybe bend the tang that pushes the switch so it makes contact again.
F-I-T
05-10-2008 19:25:51
 Re: Defect?? in reply to Mike M, 05-10-2008 13:03:02
Yeah, I can't understand what he's saying here. Even the parts book shows ALL "B"s from 201,000 and up that had the full flywheel cover used the pop out center. Perhaps the defect is that he can't see the center cover is separate?
Bob
05-10-2008 11:37:58
It's sure no DEFECT when it keeps blems from hand-cranking the starter-equipped engines by grabbing the flywheel, and getting torn apart by the ring gear!
Den N Ms
05-10-2008 13:42:55
 Re: Defect?? in reply to Bob, 05-10-2008 11:37:58
Bob,I once saw a man at a tractor pull in Marshall Ill loose all four fingers on a hand.They had the flywheel cover off.He was tryin to start it up on the back of a truck.He had his brother step on the starter while he was gona pull it through.He grabbed that flywheel and pulled on it before I could stop him.Ran his hand between the flywheel ring gear and the engaged starter drive.He lost all four.
Bob
05-10-2008 14:46:21
 Re: Defect?? in reply to Den N Ms, 05-10-2008 13:42:55
DAMN!
RobMD
05-10-2008 12:18:27
 speaking of which... in reply to Bob, 05-10-2008 11:37:58
Bob, One time I was trying to free up a stuck 530 LP, and when it got to the point of being loose enough to rool back and forth by hands with moderate effort, I mangaged to skin all four knuckles near the starter area as it suddenly went all the way around.
Wilamayb
05-10-2008 21:52:19
 Re: speaking of which... in reply to RobMD, 05-10-2008 12:18:27
You forgot to let go somewhere between 12 oclock and 6 oclok LOL!
RobMD
05-10-2008 22:16:26
 Re: speaking of which... in reply to Wilamayb, 05-10-2008 21:52:19
Oh yeah, just kept on pushing, it was getting freer, and I was getting happier...
Happiness suddenly turned into a raging, hopping fit in which the entire village could hear my curses.
Bob
05-10-2008 12:50:05
YIKES!!!
