4020 Hydraulic Screens
Mark J.
05-04-2008 16:47:09
I have a 1965 4020 gas with power shift. I'm using it with a JD 48 loader and secondary spool valve. At the moment I'm running it off the old single remote. The problem I'm having is the dashmount handle keeps popping out. Also, there is a noticable load on the engine while I have it engaged and the loader stationary. Someone suggested I clean the filter screens, but I've been told two different ways to do it. The next time I drain the hydraulics I want to clean them out and also tap the oil filter housing to free up the single remote.
So where are the screens located? I've heard you can access them from under the tractor and I've heard you can get to them by taking the filter elements out. I'll have to wait a week or two for the mud to dry up before I can crawl around under the tractor to look for access covers. My operator's manual says take it to the dealer.
Sorry for the winded post, but that's the situations,
Mark J.
buickanddeere
05-06-2008 05:27:26
 Re: 4020 Hydraulic Screens in reply to Mark J., 05-04-2008 16:47:09
Sound like there is only gravity feeding the carb at the moment. It certainly could be something odd as the problem. You just never know what some tinkerer may have done or just age and wear from the past 40+ years.
buickanddeere
05-05-2008 11:00:12
After verifying the previously mentioned possible open center/closed conflict. And checking to make certain the relief valve in the loader control isn"t opening below normal hydraulic system operating pressure. If it is opening the hydraulic system will be pumps full time loading the engine, heating the oil & wasting fuel. Next, get rid of the current loader hydraulic connection to the SCV. The rear remote is fine for occasional use remote hydraulic ram"s on cultivators etc. It"s not fine for high flow, high usage loader operation. Instead of starving the oil pump. Return the loader oil through the ported filter cover # AT30197. It doesn"t matter what else you do with bungee cords etc. Unless the oil from log splitters, backhoes, loaders, oil operated seed planter motors etc. Is returned to the filter cover. The system isn"t going to work worth beans. Mother Deere makes the covers for a reason. Next instead of a "farmer fix" with the bungee cord on the dash and still tying up the rear remote scv. Get a T fitting and supply the loader valves directly from the front pump"s high pressure outlet line. With everything else in proper configuration & repair. You won"t believe it"s the same tractor and loader when properly plumbed direct. We were amazed when we fixed up the tinkeration somebody did on the 2020"s model #48 loader and went direct.
Bob
05-04-2008 18:43:40
Tie the console hydraulic handle in place with a tarp strap or bungee cord.
If it is loading the pump when you pull the dash lever, either the remote valve is set up for "open center", or is leaking internally, OR the tractor's SCV needs repairs or adjustment.
Third Party Image
The screen, #28, is located behind plug #26, below the transmission and hydraulic filters.
You can change the filters without draining the hydraulic oil, but the screen is at the bottom of the sump, and ALL the oil needs to be drained before attempting to remove it.
There's also a little screen in the stroke control valve section of the main (front) pump.
Mark J.
05-04-2008 19:43:38
 Re: 4020 Hydraulic Screens in reply to Bob, 05-04-2008 18:43:40
Thanks. Now I know what to look for. That diagram helped out a lot.
I don't know what the previous owner used for hydraulic oil, so if I have to add much I'll change out all of it. Use the old stuff in another tractor that uses 10 gallons or less.
Sadly, while moving some brush today, the 4020 decided to quit running out in the pasture. It starts and runs for 10 seconds then dies. Looks like I have a fuel problem to solve before I can work on the hydraulics. So much for testing out the loader.
Mark J.
Mark J.
05-05-2008 17:04:03
 Re: 4020 Hydraulic Screens in reply to Mark J., 05-04-2008 19:43:38
Well I drove out to the pasture after work today with the toolbox and an airtank. I took the gasline off at the carb and blew in it as carefully as I could. It blew bubbles back into the gas tank. I only have about 12 inches of gas in there so it didn't take a lot of pressure. However, I figure a check valve somewhere in the line should have kept the air out of the tank. The tractor ran great for 2 mins then died. I was able to get the tractor back near the shed by driving 20 yards at a time and then waiting for the carb to fill up again.
I'm probably looking at a new pump one way or another. It is either a blown diaphram or stuck check valve. It isn't an original pump. There is no bowl on top. I also had to connect the line with two elbows to clear the diaphram housing. The previous owner wasn't able to tighten down the fittings.
That's the update for now,
Mark J.
Mike M
05-05-2008 05:18:30
Check for fuel flow out of the transfer pump to the carb.
Bob
05-04-2008 19:56:45
Mark, you could have clogged fuel filter(s), or an other restriction in the fuel supply system OR problems with the injection pump. Take a look at the old thread linked below, about a similar problem with a 5020:
