It's one of those things you'll have to check for yourself!
Bob
04-20-2008 17:15:17
EITHER can cause obnoxious noise.
doubleb
04-20-2008 17:45:50
 Re: It's one of those things you'll have to check for you... in reply to Bob, 04-20-2008 17:15:17
Well Bob any way to tell with out replaceing the coupler?
Bob
04-20-2008 17:58:37
 Re: It's one of those things you'll have to check for you... in reply to doubleb, 04-20-2008 17:45:50
The coupler can get loose on the pump splines. If that is the case, there probably will be rusted metal filings visible in the joint between the coupling and the pump shaft.
They also get loose in the bolt-together coupling, when the "doughnuts" fail. You can PROBABLY detect looseness there by wiggling the pump shaft back and forth with a Channel-Lock.
If the splines are tight, and it's been a while since the plastic "doughnuts" have been replaced, it's probably just as well to split the coupling, and replace them. The are CHEAP, compared to any pump problems! Then, you'll know!
msb
04-20-2008 19:23:20
 Re: It's one of those things you'll have to check for you... in reply to Bob, 04-20-2008 17:58:37
A 24"- 3/8 "extension bar, a ratchet and a 9/16 " deep well socket makes quick work out of replacing the nylon bushings and you will know, like Bob says. That is where I would start.
