70 4020 hydrualic punp knock
doubleb
04-20-2008 17:03:55
I noticed the front pump knocking today. It doesn't seem to knock much when I have a remote in use and knock is different when you move the steering.Do you guys think this is the pump or the coupler thanks?
6030MATT
04-21-2008 23:04:52
 Re: 70 4020 hydrualic punp knock in reply to doubleb, 04-20-2008 17:03:55
We just had a tractor do this, ended up being the crackshaft dampner. The noise or knock would virtually stop when the hydraulics were in use or when you were steering the tractor but then came back when not in use. Now this was a 4650 so way different tractor and I dont know much but just a thought. Good Luck, hope all goes well.
6030MATT
04-22-2008 18:52:06
 Re: 70 4020 hydrualic punp knock in reply to 6030MATT, 04-21-2008 23:04:52
Yeah After looking at a 4020 it doesnt look like they have a cranckshaft dampner, my bad.
doubleb
04-20-2008 19:48:09
Thank you guys for the tips. If it is the pump should I get one from deere or is there some good rebuilt ones some where?
rexhellwig
04-21-2008 16:49:35
 Re: 70 4020 hydrualic punp knock in reply to doubleb, 04-20-2008 19:48:09
A new pump from Deere is foolproof, and you are gouged accordingly.
Some folks on this forum do claim good results with "off-breed" pumps. {The only ones I have seen are very poor quality and have very high failure rates. A seasoned Deere mechanic can build a much better pump from used parts.} If you are going to hire this done, let your own mechanic advise you.
rexhellwig
04-20-2008 18:39:28
After the engine has been shut off for several minutes, Grab the pump shaft from underneath the tractor and try to "twist" the shaft back and forth against the engine. If you feel motion, tear it down now. The plastic drive bushings are probably worn. {Cheap to fix} If you keep running it and break the bushing drive screws off in the crankshaft damper, you'll wish you hadn't.
If this is OK the source of the noise is in the pump itself. {More $$} These pumps will chatter/knock when they don't get enough oil.
My guess? The way you describe the knock sounds like what typically happens when one or more of the eight pump inlet valves lose their press fit. They will then bang between their original seat ane the inlet valve plugs. You'll need a new pump to fix this right. Staking and loctite applied to the worn parts isn't worth trying if you are paying someone to do the work.
Bob
04-20-2008 17:15:17
 It's one of those things you'll have to check for yourself! in reply to doubleb, 04-20-2008 17:03:55
EITHER can cause obnoxious noise.
doubleb
04-20-2008 17:45:50
 Re: It's one of those things you'll have to check for you... in reply to Bob, 04-20-2008 17:15:17
Well Bob any way to tell with out replaceing the coupler?
Bob
04-20-2008 17:58:37
 Re: It's one of those things you'll have to check for you... in reply to doubleb, 04-20-2008 17:45:50
The coupler can get loose on the pump splines. If that is the case, there probably will be rusted metal filings visible in the joint between the coupling and the pump shaft.
They also get loose in the bolt-together coupling, when the "doughnuts" fail. You can PROBABLY detect looseness there by wiggling the pump shaft back and forth with a Channel-Lock.
If the splines are tight, and it's been a while since the plastic "doughnuts" have been replaced, it's probably just as well to split the coupling, and replace them. The are CHEAP, compared to any pump problems! Then, you'll know!
msb
04-20-2008 19:23:20
 Re: It's one of those things you'll have to check for you... in reply to Bob, 04-20-2008 17:58:37
A 24"- 3/8 "extension bar, a ratchet and a 9/16 " deep well socket makes quick work out of replacing the nylon bushings and you will know, like Bob says. That is where I would start.
