Here is my .02 I work at a Deere Dealer in the parts department. I have been to several classes on engine oil that compare different brands and types of oils. I used to think that all brand name 15-40's were the same until I saw some test results.Deere does not deny that Rotella or Delo 15-40 engine oils are bad. They agree that they are high quality. In most cases, Shell or Chevron mix Deere's oil, depending on the reigon. But, those oils are developed for engines that run at around 30% load, 80-90% of the time. Deere has additives that they specify to be added to bring the oil to their specs. This gives it the ability to run at 80-90% load at 80-90% of the time. When you start comparing prices, they arent that different. In Deere tests, they do pretty much all they can to destroy and engine and the oil in it. After these tests they compare all parts of the engine, bearings, pistons, cleanliness of parts and other major components. The results are pretty amazing. The Deere oil, with the extra additives out performed the others signifigantly. In older equipment, that runs slower RPM's and looser tolerances, 15-40 works fine. In higher rpm, closer tolerance, newer engines, like small cars and small engines, a 5-30 or 10-30 is a better choice. I have rebuilt many engines at the dealer when in was in the shop, and it was easy to tell someone who used Deere engine oil, and one that used another brand. The insides were always cleaner and had less wear. anyway, enough rambling. I hope this didnt confuse anyone.
