Anyone use 15W40 in their gas tractors
Farmer Jack
03-10-2008 16:50:08
I am considering consolidating my engine oils to 15W40 which I used on my diesels. I am wondering if anyone uses 15W40 in their two cylinder and/or bigger gasoline powered tractors.
Jake Winn
03-12-2008 20:01:29
 Engine oils in reply to Farmer Jack, 03-10-2008 16:50:08
Here is my .02 I work at a Deere Dealer in the parts department. I have been to several classes on engine oil that compare different brands and types of oils. I used to think that all brand name 15-40's were the same until I saw some test results.
Deere does not deny that Rotella or Delo 15-40 engine oils are bad. They agree that they are high quality. In most cases, Shell or Chevron mix Deere's oil, depending on the reigon. But, those oils are developed for engines that run at around 30% load, 80-90% of the time. Deere has additives that they specify to be added to bring the oil to their specs. This gives it the ability to run at 80-90% load at 80-90% of the time. When you start comparing prices, they arent that different.
In Deere tests, they do pretty much all they can to destroy and engine and the oil in it. After these tests they compare all parts of the engine, bearings, pistons, cleanliness of parts and other major components. The results are pretty amazing. The Deere oil, with the extra additives out performed the others signifigantly.
In older equipment, that runs slower RPM's and looser tolerances, 15-40 works fine. In higher rpm, closer tolerance, newer engines, like small cars and small engines, a 5-30 or 10-30 is a better choice.
I have rebuilt many engines at the dealer when in was in the shop, and it was easy to tell someone who used Deere engine oil, and one that used another brand. The insides were always cleaner and had less wear.
anyway, enough rambling. I hope this didnt confuse anyone.
Texasmark
03-13-2008 07:04:28
 Re: Engine oils in reply to Jake Winn, 03-12-2008 20:01:29
Interesting, and I mix Deere 50 whatever oil 50-50 with my Rotella T full syn. Also notice on the Deere container that they will repair any engine that fails using their oil...oil related problem.
And the price, as you said was competetive. I like at least some full syn in my crankcases and the local Deere dealer doesn't stock full syn. so I use Rotella T for that part.
Mark
scooter01922
03-11-2008 12:30:22
 Re: Anyone use 15W40 in their gas tractors in reply to Farmer Jack, 03-10-2008 16:50:08
Rotella T 15-40 in pretty much anything here with an engine :-) no issues yet.
sodly
03-11-2008 08:18:34
I used to use Rotella in everything... tractors, cars, etc. However, after using it in my 4 cylinder toyota corolla in the winter I started to develop some valve clatter at cold temp startups. I switched back to 5w-30. I wish I could use Rotella in everything but I'm a little afraid of it at real low temps. Anyone else have similar problems with it?
Texasmark
03-13-2008 06:59:45
 Re: Anyone use 15W40 in their gas tractors in reply to sodly, 03-11-2008 08:18:34
I have always been a thick oil nut cause I watch oil pressure, especially when the engine is hot. I forget which oil I had in my '88 Ford 302v8 but it was probably `15w-40. I keep my oil changed and live in the country so not many short trips but anyway, every time I would change oil, even filling the new filter with fresh oil, I would get a little valve clatter racket a second or two before the oil pressure responded to the new oil.
I went to full synthetic and never had that happen again. I have to use thinner oils now as the new oil pumps in newer vehicles are designed for them, but I only put full syn in my trucks and either full or blend it in my tractors.....can't afford full syn on the big tractor. Course Rotella T's full syn is 5w-40 which makes it really nice and it is heavy duty oil and (C ratings) and somewhat cheaper than Mobil 1 at wally world.
Mark
Mike M
03-11-2008 11:23:16
I had one cold startup with my truck and it had me worried. I did add some rislone before winter when I changed the oil. I was debating of using 10w30 but used what I had. If it gets really cold that 15w40 is thick.
Texasmark
03-11-2008 08:15:48
Me too unless I am using their full syn 5W-40. Used to use it in my trucks too till I bought new ones and they insisted on using a lighter oil.
Mark
dlplost
03-10-2008 23:38:52
15w40 Rotella T, use in it in JD 2010 Diesel dozer, IH TD-9 Dozer, 2 Ford 8n's, and everything else..NEVER had a problem with it here in NY State.
Mike M
03-10-2008 18:13:23
I got a deal on a drum years back and use it in everything,pick-up,lawn mowers,compact diesels. I'm out now I'll have to buy some at full price ! Nothing more simple than one oil for all.
Hoss in ME
03-10-2008 16:53:58
I use 15-40 rottella in all my tractors,2JDs a case diesel and a massey pony. Good stuff! Later Hoss
