Fuel gauge /sending unit
sgt bull
03-05-2008 08:47:57
After reading in an earlier thread about the usability of the sending unit from an 80 on a 630 with only slight modification, I called my local dealer and ordered one. They advised it was no longer available, but found one at a dealer in LA. THAT one, for some reason, was "back ordered". Not sure what that means, when it's supposed to come from a dealer's shelf. Maybe they have to look further back in the shelf. Anyway, this is a working tractor, and even though the price was only $69 bucks, which is the cheapest I've found on a regular Deere sending unit, I had to get it back together and couldn't wait for a taller parts man in LA to look further back in the shelf. I called my local NAPA, and asked about a, shudder, GENERIC guage and sending unit. They had one. $35.00. I decided to take a chance, and bought it. I'm not thrilled with the red needle or the chrome bezel, but it works fine and the black face doesn't look too bad. At least it keeps me from becoming a pedestrian from the back 40. The only problem I found was that the guauge ONLY works with negative ground, so I had to switch the terminals on the coil, ammeter and of course the battery, then repolarize to switch my positive ground system over. Not a big deal, since I had the fuel tank off and the back of the dash was easily accessible. Just thought I'd share that, in case someone else is fighting the same battle.
Texasmark
03-06-2008 15:56:10
 Re: Fuel gauge /sending unit in reply to sgt bull, 03-05-2008 08:47:57
I tried such and was totally dissatisfied. Reason being is the torture the gauge takes on a farm tractor. My NAPA lasted about 6 months. So I bit the bullet and got one from my local JD dealer for twice the price, but the construction was like 4x more husky and that was well worth the $65 price.
Mark
sgt bull
03-07-2008 18:46:57
 Re: Fuel gauge /sending unit in reply to Texasmark, 03-06-2008 15:56:10
what part of your napa system failed?
Texasmark
03-08-2008 07:50:12
 Re: Fuel gauge /sending unit in reply to sgt bull, 03-07-2008 18:46:57
The wire which the float arm rubs on rubbed into which obviously opened the circuit. It was a really tiny wire, maybe 60 AWG; course it was probably made of titanium or something like that.
On the JD unit, this function (float position information) is on a metallic coated piece of ceramic material like integrated circuitchips mount on and it is fatter than the wiper arm so there is material that the wiper doesn't contact so it can't wear into. Course at the end of life, either the tab on the arm will wear off or the deposited conductor material will wear through.
Mark
Kentb of SWMO
03-06-2008 09:17:33
Stewert-Warner gauges use a 33 to 240 ohm range sender. Almost all older cats use the Warner system EXCEPT GM which use 90 to 0 ohms. If JD uses the Warner system you should be able to use a universal sender for the Warner system with the JD Ggauge.
Kent
F-I-T
03-06-2008 13:28:54
 Re: Fuel gauge /sending unit in reply to Kentb of SWMO, 03-06-2008 09:17:33
The original gauge was AC Delco and used a 0 to 30 sender.
F-I-T
03-05-2008 09:31:10
You might be referencing the thread where I posted about suing the 80/820/830 unit numbered AR1112R. I just checked JDParts.com and it shows available at $70, and so I called my dealer and he said they have them in the Milan parts center. In fact, I must have been buying them regular, since I fixed several, that they show one in stock in little old Tallahassee, which is primarily a lawn and garden dealership. Last I got was about a month ago and it is now in my 70D working fine. Not sure what's up with your dealer unless he typoed.
Here is another sender that is a 0-30 ohm unit which is virtually identical Stewart Warner unit.
third party image
Of course the sender does not care if you have it as positive or negative ground, but the old AC-Delco fuel gauge did require positive ground. I am currently working on a bread board project using a Jeep 6 volt gauge that looks to be very similar to the untrained eye to the original AC unit.
third party image
I hope to get that all worked out soon, but based on my schedule these days, that might be unrealistic. See link to old YT thread for after market sender.
sgt bull
03-05-2008 16:04:43
 Re: Fuel gauge /sending unit in reply to F-I-T, 03-05-2008 09:31:10
the aftermarket i purchased looked nearly identical to the one you pictured. It was surprisingly easy to install, and all the hole lined up just fine. If it was a show tractor, I'd be more concerned about the chrome bezel and red needle, but this one is a worker, and I'm more concerned about walking a mile and half home,('cause my wife will be on the internet, and her cell phone will be ringing away in the console of her car, as I become madder, and madder, and madder!)
F-I-T
03-05-2008 17:01:54
 Re: Fuel gauge /sending unit in reply to sgt bull, 03-05-2008 16:04:43
Been there, done that, got the T-shirt. :)
Besides, you're never out in the shop working. You are "tinkering"....
61-4010
03-06-2008 03:28:13
 Re: Fuel gauge /sending unit in reply to F-I-T, 03-05-2008 17:01:54
I"d gladly take "tinkering"! My bride says I"m out in the shop "playing."
