Another Fuel Gauge Question for F_I_T
Tom43
12-30-2007 19:07:10
Dear F_I_T,
When and why did Deere go to the 240 ohm sender that reads full when the lead is grounded which is the opposite of the 30 0hm sender?
John T
12-31-2007 06:52:34
 Re: Another Fuel Gauge Question for F_I_T in reply to Tom43, 12-30-2007 19:07:10
Tom, Although fuel gauge current draw is so low to begin with, I wonder if that had anything to do with the design change?? Some of the auto companies went to the flasher/pulser gauge system, maybe to save energy and the smaller wires??
Hope we can catch each others Workshops at GOG, I think they have me down for 2 electrical and another round table with Don Ward, hopefully none conflict with yours on 24 volt
Link
F-I-T
12-30-2007 19:30:53
When, I can't say. I think it was quite a while back, maybe 10 years. The original gauge and sender are AC Delco units, and I guess AC just stopped supplying them. I have re-wound the resistors, and you can get gauges and senders rebuilt, or on exachange. Nick Barbieri is one source. And, if you want to do a bit of modifying, the sender that is used on the 80/820/830 is still available, but probably only until the current stocks are depleted. The head is the same, but the arm is longer, so you have to cut it shorter, add a loop for the float, and re-bend it to fit your tank. I have one on the way from Deere right now that I will modify for my 70D.
I am also currently experimenting with a 6 volt unit from a Jeep, and the dog-gone thing looks really, really close to the AC unit, but it would require a different sender. I'll probably be able to offer more information on that later.
HTH
Frank
WeirdDeere
12-30-2007 20:56:50
 Re: Another Fuel Gauge Question for F_I_T in reply to F-I-T, 12-30-2007 19:30:53
I can"t remember the last time I bought the 80 type sender...about a year ago? I"ve gone through two or three now (I burned up one). One was like you mention, where it was solid, and I had to cut the float arm to the right length and re-solder the float back on. Another was a "one size fits all" where you HAD to adjust/cut the arm to the proper float travel. Which is nice when you have to modify it for non specified uses. But it also had plastic parts, which stinks.
But I"m thinking if they made it more of a "one size fits none" style, that they might keep it around for a while. That"d be nice anyway.
Brandon
F-I-T
12-30-2007 21:09:17
 Check out this bargain!!! in reply to WeirdDeere, 12-30-2007 20:56:50
third party image
Ask and you shall receive. A universal, fit-it-to-your tank 30 ohm sender with what looks to be the correct top. $28.00. Now I'll go looking for a sender for that Jeep gauge and we might have a functioning set from under $50.00
WeirdDeere
12-30-2007 21:21:59
 Re: Check out this bargain!!! in reply to F-I-T, 12-30-2007 21:09:17
That looks pretty similar to the one I received from Deere. I'd bet it's from the same supplier (without a JD markup?). I think the one I had said Stewart Warner somewhere...
Brandon
F-I-T
12-30-2007 21:32:59
 Re: Check out this bargain!!! in reply to WeirdDeere, 12-30-2007 21:21:59
Last one I bought from Deere was the AC Delco two winters ago.
Duane(Pa)
12-30-2007 19:40:35
Was toying with the Jeep guage idea. Would it be Pos. ground? or would that even matter?
F-I-T
12-30-2007 20:04:24
 Re: Another Fuel Gauge Question for F_I_T in reply to Duane(Pa), 12-30-2007 19:40:35
third party image
The one I'm playing with does not seem to care. It has three terinals, one ground, one hot, one for the sender. I just haven't got down to the nits and lice of what the sender resistance has to be. I think it is a 240 ohm. Here's the gauge. I think it would pass for everything but maybe Expo judging.
