Regen -- Hood decals come into mind as one tries to differentiate between a 41 and 42. The 1941 "H" tractors were in a decal class by themselves, using the larger size letters found on 39-40 tractors, but with a black border around the yellow lettering. Beginning with the 42 production run, decal size was reduced and remained the same until the end. There were other changes within this production years as well -- so when ordering your decals from Travis Jorde, be sure to provide serial number so you receive the right ones. See "Decals" at the JD-H restoration site (below). Scan across to ARTICLES 1, and then from the drop-downs, selct DECALS. The serial number data I use is from charts issued in various forms by Two Cylinder. Their serial number data is widely accepted as the industry standard. Bear in mind too, that Deere's production years were aligned (more or less) with the federal fiscal years, and so your tractor was very likely shipped from the factory in July or August of 1941 because it is an "early" 1942 tractor. Finally, as Mike says, when procuring replacement parts, model and serial number are the key data points. Check you parts catalog. Not one place in that publication will find the year of production -- only serial number. Have a fine one! (PatB)
