Joe,Your post below regarding �John Deere Serial numbers� is of some interest to me. The fellows that responded gave you good and accurate information, but I�d like to toss in a couple of words about this, and since this is such a long note, I decided to start a new thread. First, a little history: Some of the confusion about �model years� is because of terminology. For example, you have model years, product years, manufacturing years, fiscal years, calendar years, and who-knows-how-many other types of years referenced in literature that discusses the age of JD two-cylinder tractors. The first real effort in compiling lists of model years of John Deere Tractors was in 1976, when the late Will McCracken (Product Publicity, Advertising Department, Deere & Company), edited the first of several booklets published by Deere that were entitled, "John Deere Tractors, 1918-1976". Those booklets contained a brief outline and description of tractors associated with John Deere during that timeframe, and as sort of an appendix, the last several pages listed model years with the beginning serial numbers of those years. The Two-Cylinder Club then published most of that data onto those little wallet cards (which many other organizations quickly copied as their own, as well). Now, here�s where the confusion starts. In that booklet, the preface to the model year/starting serial number list says, "The serial numbers beginning below provide a means of determining your tractor"s age. The number opposite each year designation is the beginning serial number for that year for the model designated in the headline. Years are product years (usually 1 August of the preceding calendar year to the following 31 July) unless noted...� Next, let"s look at an article in the December 1996 issue of Green Magazine. In that article, it is stated (referring to the above John Deere Tractors booklet), "This otherwise excellent book was flawed only by the author"s assumption that tractor model years began and ended at the same time Deere & Company"s fiscal year did (November 1 - October 31) which was true until the 1939 model year, with a few exceptions which will be explained later. The serial number breaks in this book can be considered more or less accurate up until 1941 or so, at which point they begin to deviate quite seriously from the information contained in the serial number register." Actually, it appears everyone has misstated some facts. Green Magazine says the serial numbers were wrong (true), but says it was because the author assumed models years corresponded with fiscal years (not true, according to the statement in the Deere booklet). But at least now, everyone seems to agree that models years corresponded with the summer shutdown dates at the Waterloo factory � at least as far the as the model H is concerned. Unfortunately, that original John Deere Tractors booklet (brown cover) contained inaccurate information, and it was perpetuated by the early Two-Cylinder Club wallet cards. Subsequently, later editions of the John Deere Tractors booklet (ones with the gray cover) corrected the earlier errors. And, some years ago, the Two-Cylinder Club posted a note stating, "Interestingly, most of the starting serial numbers for two-cylinder tractors published in the 1976 book have since been nudged aside by different numbers." So now it appears that despite 20+ years of confusion, all the authorities now agree on model years and their corresponding beginning serial numbers. But the biggest problem is the fact that �model years� are of little value for anything. And the reason for this is because, with very few exceptions, nothing changed on the tractors at the time of a new model year. For example, I can think of only two times when changes were made to H"s that actually coincided with the beginning of a model year. Probably the most significant change, for s/n 10000, does happen to coincide with the beginning of the 1940 model year � but only if you use today"s interpretation of model years. A more modest change, to steel front wheels from cast iron, coincides with the beginning of the 1945 model year, and coincidentally, also matches the beginning of the 1944 model year in the 1918-1976 book! Most all of the other significant changes, and availability of new options (such as another big, big change to accommodate electric starting and lights) for the H were mid-year model changes, no matter which serial list you choose to believe. And, there were lots and lots of little mid-year model changes you will find by sifting through parts books. So my contention is that we should be paying less attention to the �model year�, and more attention to the build dates and serial numbers.
