ID'ing a suspected JD plow
Tbolt76
02-06-2008 18:30:17
I was checking out a 2 bottom plow I saw today. The only numbers I could find were stamped on the the main beam. The plow was green with the characteristic yellow on the furrow wheel. The # was A11247. Any help out there? Thanks.
Bob Collins
02-07-2008 05:14:46
 Re: ID'ing a suspected JD plow in reply to Tbolt76, 02-06-2008 18:30:17
As a matter of fact you did give good info, and A11247 is the beam number for a 415 or 416 John deere plow.
Tbolt76
02-07-2008 16:02:07
 Re: ID'ing a suspected JD plow in reply to Bob Collins, 02-07-2008 05:14:46
Bob, Could you recommend a source to look up such numbers like this and for other implements? Thanks!
Bob Collins
02-07-2008 17:25:12
 Re: ID'ing a suspected JD plow in reply to Tbolt76, 02-07-2008 16:02:07
In this case I used the John Deere Master Parts Index, original copies are hard to find and usually expensive. There photocopies available from time to time. Maybe someone else can suggest a source, I can't think of one right now.
Will P
02-06-2008 19:59:35
Pat is talking of this thread, which I have replied on.
Will
Tbolt76
02-07-2008 04:11:52
 Re: ID'ing a suspected JD plow in reply to Will P, 02-06-2008 19:59:35
Maybe I should've mentioned the plow I'm looking at is a 3pt and not a trailer type. Thanks.
P Browning
02-06-2008 22:01:52
Thanks Will -- It totally escaped me to provide the link as you have. Well done! (PatB)
P Browning
02-06-2008 19:34:40
Good! That describes millions of plows! Try taking a look at the plow identification thread initiated on 2-5-2008 here on this forum. The interchange of data was superior to many posts and got to the bottom of the puzzle right away. It may help you as well. (PatB)
