Plow Identification
wilamayb
02-05-2008 17:02:53
This is an old plow that came with an unstyled tractor. One beam has a stamped "62" and the other has a "63". From the pictures I've seen so far it looks like a 4B. Is that right? If so where can I get a set of replacement shares? Mine appear to be deep suction style.
Thanks!
third party image
third party image
wilamayb
02-05-2008 17:50:22
 Re: Plow Identification in reply to wilamayb, 02-05-2008 17:02:53
Thanks for the ID guys! Now what about replacement shares? Can I exchange them for new style shares or can I find deep suction replacements somewhere?
Will P
02-05-2008 20:24:58
 Re: Plow Identification in reply to wilamayb, 02-05-2008 17:50:22
It is an early 52 plow. I don"t have my books here, but probably 1934-1937 You can tell by the hitch parts that it is early.
Will
Bob Collins
02-06-2008 06:22:22
 Re: Plow Identification in reply to Will P, 02-05-2008 20:24:58
Will, I look for the "ears" where the levers overlap to tell if it is an early (1934-1935) model(and it looks like this has them). My parts catalog shows the same spring release hitch available for the whole production run. What tipped you off that it was early?
Will P
02-06-2008 14:57:50
 Re: Plow Identification in reply to Bob Collins, 02-06-2008 06:22:22
Look at the bracket that holds the spring up with the hand crank. The bracket became arched to clear the crank. So you won't hit your knuckles on the bracket when you crank the crank. Clear as mud?.
Will
Bob Collins
02-07-2008 05:03:42
 Re: Plow Identification in reply to Will P, 02-06-2008 14:57:50
Good observation, I had missed that, thanks. Bob
Bob Collins
02-05-2008 17:46:05
Look closer and you will see the "1" between the 6 and the 2 and 6&3 on the beams. The #52 looks very similar to a 4B but has only three braces between the beams where the 4B has 4 (along with a lifting spring to help with heavier plow), smaller diameter axle stock (1 1/2" Vs. 1 3/4") Master lever on a 4B is straight, 52 has slight bend. #52 has "flat" hub cap on furrow wheel etc., etc.
The Dukester
02-07-2008 18:43:06
 Re: Plow Identification in reply to Bob Collins, 02-05-2008 17:46:05
Bob, didn't most 4B's with steel wheels have a larger diameter land wheel, that is somewhat larger than the furrow wheel?
Bob Collins
02-07-2008 18:59:58
 Re: Plow Identification in reply to The Dukester, 02-07-2008 18:43:06
Dukester, Yes the first 4B plows on steel had a 32" land wheel with a 26" furrow wheel. Sometime in 1941/42 the land axle was changed making the vertical portion longer and the land wheel was changed to a 26" diameter. The apparent explanation is; at the same time when optional rubber tires were furnished, or at least when wheels FOR rubber tires were supplied, the size was reduced from the earlier 21" wheel to a 16" wheel (tire). Farmers and/or dealers bought plows without tires and supplied used auto tires. In the late 30s early 40s the auto manufacturers started using the 16" tires so availability was better than the (becoming) obsolete 21" size.
jdal
02-05-2008 17:28:04
Looks just like my model 52, are you sure on the beam numbers. Mine are 612 and 613.
Bill-NNY
02-05-2008 17:19:07
A 4B plow hitch had a heavier hitch brace, where the round rod connects to the hitch. I dont have the Green Mag beam # cross reference handy.
The hitch to me looks like a 52 model. just my 2 cents,,,
Bill
