Steering problem on my 50
DaveS
12-20-2007 13:44:20
My 50 has always steered very easily to the right, and if I let go of the wheel while moving it tends to go to the right.
This morning I got it out of the shed and as soon as I started it, the wheel went to the right and it continued to go right when I let go of the wheel until it warmed up some.
I'm sure this is not going to go away on its own, so I guess while it's winter out I need to do something about it. Problem is, I don't know what to do. Can anyone point me in the direction of the most likely problem spot and what should I look for to fix it?
RobMD
12-20-2007 15:10:19
 Re: Steering problem on my 50 in reply to DaveS, 12-20-2007 13:44:20
Your steering valve is not centered. Do you have a service manual? It'll tell ya that you loosen 4 bolts and knock the valve backwards or forwards with the tractor running.
F-I-T
12-20-2007 20:47:30
 Re: Steering problem on my 50 in reply to RobMD, 12-20-2007 15:10:19
third party image
Here is good old thread and a nice photo.
Frank
DaveS
12-21-2007 02:56:50
 Man that makes life easy =) in reply to F-I-T, 12-20-2007 20:47:30
Thanks for the pic and explanation. That should be easy enough to fix!
Mike M
12-21-2007 05:21:28
 Re: Man that makes life easy =) in reply to DaveS, 12-21-2007 02:56:50
Just want to add that VERY LITTLE movement of that valve housing can mean a BIG difference. It is very touchy !
F-I-T
12-21-2007 08:04:38
 Re: Man that makes life easy =) in reply to Mike M, 12-21-2007 05:21:28
You got that right! I've never measured it, but I'm pretty sure that you'd be talking bumping it few thousandths one way or the other. Certainly not much more than the scribe line width.
DaveS
12-21-2007 16:37:24
 Re: Man that makes life easy =) in reply to F-I-T, 12-21-2007 08:04:38
Wow. So just a little bit goes a long way. I'd probably have had it going the other way... a Lot haha. Thanks for that bit of info too.
DaveS
12-20-2007 18:21:02
 Found another post... in reply to RobMD, 12-20-2007 15:10:19
Someone else had that problem and a couple people told him to get a manual because there was a lot to it, So that is what I will do.
Thanks
DaveS
12-20-2007 18:10:05
No, I don't have a manual for it. Maybe I can do a search on that and find out how to do it. Is this valve up front near where you add fluid?
RobMD
12-20-2007 21:30:41
 Re: Steering problem on my 50 in reply to DaveS, 12-20-2007 18:10:05
Look at frank's picture. It's very easy to center your valve. when you loosen those four bolts just enough to move the part back and forth, then that's what you do... move it back and forth, tighten where you think is right, if not, loosen and go at it again. might have to use a handy little plastic hammer to get that thing moving, but NOTHING like a ball peen hammer which i've seen BOOGERS the end of that thing!
