720 power sreering problem
Carl
03-04-2004 16:10:11
Just picked up a gas 720. The problem is that the steering wheel turns to the left without touching the steering wheel. It steers all right but if you let go of the wheel it goes left. Is this a major fix?
Roger
03-04-2004 20:13:52
 Re: 720 power sreering problem in reply to Carl, 03-04-2004 16:10:11
Carl, I went through this too, what I did was, I took a small chisel & made a mark across both pieces on top as a starting point to see how much I was moving the valve. It don't take much, sometimes I didn't think I moved it at all & it steered different. Sometime only thousandths of an inch may be too much, that's how touchy they can be.
Clooney
03-04-2004 17:49:33
third party image
Carl, Frank pretty well covered the basics.. This picture will give you some idea of where you need to start.
~Get the tractor hot, then park the tractor on a fairly high traction surface, then loosen the 4 bolts shown & bump the gear s-l-i-g-h-t-l-y in the direction shown until it takes the same turning force on the steering wheel to turn it in both directions from center.. CAUTION: don't stand between the right front wheel & the tractor when adjusting as a slight movement of that gear can cause the wheels to cramp quickly to one side & pinch you..
~OK, now that you know what needs to be done give it a try.. If you get it adjusted but the steering then has a catch or lock up when turning you could have some steering sleeve wear or other internal steering wear & the previous owner might have purposely mis-adjusted that steering to keep it from hanging up.. If that happens, put it back where it was & post back as you will need to pull the steering apart to check for wear.. You will also probably need a Deere SM 2050 steering service manual before working on that steering system.. Or as Frank mentioned you can get by with an I&T manual but will also need help from this board to understand how to make some of the adjustments mentioned in the I&T manual..
~If the steering does hang up when turning [usually happens when turning left] after you have the gear centered you might try removing the flow control adjuster cap then turning the flow control screw in a little to increase the flow as that can sometimes help [well actually mask] a hang-up problem...
[email protected]
scottAR
03-04-2004 19:22:57
 Re: Re: 720 power sreering problem in reply to Clooney , 03-04-2004 17:49:33
Clooney, That is some super pictures and instructions for a man in need. But I think we may need to come help you paint your tractor! Ha Ha!
F-I-T
03-04-2004 16:28:43
Carl:
It's probably as simple as re-centering the actuator valve body.
I don't have any good pictures on this computer, so maybe Clooney will stop by with his nice one that has the arrows and such on it.
Do you have a I&T manual for any of the models that had power steering? There were differences between the 50/60/70/early -20's and the lateer -20'/30's, but you can read around that. That adjustment is covered in there pretty well. It consists of barely loosening the four bolts that hold the steering worm assembly onto the side of the pedestal and tapping it fore or aft until the wheels stay centered. There are other things to try such as boosting flows and such, but I won't go there until you get a book handy or Clooney stops by to comment.
Frank
