It's NOT an *8, it's and S, fore Pete's sake!
Bob
08-28-2007 08:03:23
That terminal is NOT marked "8", it's marked "S", for "START", and it AIN'T GONNA start with nothing connected to the "S" terminal, 'cause that's what operates the solenoid!
The "R" stands for "RESISTOR", as that terminal provides battery voltage, while CRANKING, to bypass the ignition ballast resistor on gas engines so equipped for better spark while the battery voltage is being pulled down by the load the starter places on the battery.
The "R" terminal is NOT used on diesel "apps", and even if your's is a "gasser", there may be no wire to connect to it.
BE CAREFUL not to run yourself over when the starter DOES "catch"! Be SURE it's in "PARK"!
DanK-WI
08-29-2007 05:49:06
 Re: It's NOT an *8, it's and S, fore Pete's sake! in reply to Bob, 08-28-2007 08:03:23
Bob;
You are correct, it IS an "S". I connected the small diameter wire to the "S" terminal, and still nothing. Not a click, not nothin. Now what do I do? I think I need to prove that the starter works. It has not made one revolution since I got it back from the rebuilders. How would I connect wires to it either on the tractor or off the tractor to just see if the solonoid works and the starter will turn. I think I should leave the large wire from the battery connected to the large post on the solonoid. Attach nothing to the "R" post because you said it was useless. Then that only leaves the "S" terminal. I would think I need to attach a wire to the "S" terminal and momentarilly touch it to something. Do I touch it to the tractor and ground it? Will that conplete the circut to energize the solonoid? Please help. Thanks.
Dan
Mike M
08-29-2007 07:22:40
 Re: It's NOT an *8, it's and S, fore Pete's sake! in reply to DanK-WI, 08-29-2007 05:49:06
Touch from the large post to the S post and it should kick in and go. Double and triple check it is in neutral/park first !
You will need to have the starter case grounded and the other battery cable hooked up to the large starter post of course. You can test them in a vise on the bench if it is off the tractor.
