Chris...
Bob
08-16-2007 21:47:59
WHY don't you adjust the throttle linkage so the engine stops as it's supposed to, when the throttle stop is pulled, and the throttle is closed???
There should NEVER be need to "kill" it by loading it with the clutch/transmission.
buickanddeere
08-17-2007 06:45:34
 Re: Chris... in reply to Bob, 08-16-2007 21:47:59
I have to wonder where these people come from??? They stop the diesel with the decompression instead of pulling the fuel rack to zero which ends fuel injection? How they ever shut down a 70D that doesn't have a separate decompression lever? I'll bet they never pull the decompression in the starting proceedure when it's supposed to be used. Pulling the decompression only saves the ring gear. The starter pinion doesn't engage in the same spot every time. The starting engine has it's fuel valve shut off and idled back as soon as the diesel fires. It's ignition is shut off about 30 seconds later after a quick look over and around the tractor after startup.
Kemper
08-17-2007 18:40:30
 Re: Chris... in reply to buickanddeere, 08-17-2007 06:45:34
I have to wonder how buickanddeere comes up with some of his answers to these posts,the decompression pedal is so you can get the engine spinning over,not to save the ring gear, also it does not hurt to decompress after you pull the fuel lever back during shutdown,i have seen lots of people do it and i've been around 2 cylinders forever and own 2 730's myself,anytime that flywheel rocks and changes direction that fast...That my friend,is torque...and thats why they decompress...
randy hall
08-17-2007 19:40:10
 Re: Chris... in reply to Kemper, 08-17-2007 18:40:30
kemper, i am not the president of the fan club of the guy that likes john deeres and buick's but he means you save the ring gear if you use the decompression lever to stop the tractor instead of letting it stop under compression and go bang bang bang until it stops in the same place every time. a couple years ago i replaced the ring gear on my 720 because of the past owners shutting it off under compression.
Chris in MD
08-17-2007 08:41:16
What's the big deal? I'll eventually get around to adjusting the throttle. NO harm has been done in the year of having a loose throttle lever.
IN FACT, the tractor is a worn out pile of junk. I'm surprised the diesel actually runs. It genuinely needs a front to back overhaul.
If I fixed it all up, I would shut it down the right way.
I know it's not exactly standard operator procedure, but then again, it ISN'T YOUR tractor, is it?
"where do these people come from"... sounds as if you're calling everyone an idiot when they don't do just ONE THING RIGHT.
AW Puller
08-17-2007 16:05:10
 Re: Chris... in reply to Chris in MD, 08-17-2007 08:41:16
Ever think how your tractor got to the condition of "worn out pile of junk"? Just because it still runs doesnt mean you havent caused damage or needlessly increased wear on engine components.
Bob
08-17-2007 10:38:11
Chris,
You seem to have all the answers, and be a "perfectionist" in other posts you make. We're just "holding you to the same standard of excellance" in this thread! Stop being MEAN to the poor old tractor!
Just to refresh your memory:
Link
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ttalk&th=567691
55 50
08-17-2007 08:24:35
buickanddeere, Your first statement says it well and I agree with all your comments.
Chris in MD
08-17-2007 08:43:43
 Re: Chris... in reply to 55 50, 08-17-2007 08:24:35
I can see you like playing follow the leader.
buickanddeere
08-17-2007 09:42:50
 Re: Chris... in reply to Chris in MD, 08-17-2007 08:43:43
So Chris. You are saying it's fine to do things *ss backwards? To have no interest in finding out the correct way. And to find a reason to not perform a task the proper way when you do find out? New or worn out, why beat a machine with stress that will shorten it's operating life?
