Deere engineers turning over in graves
msb
07-29-2007 10:18:30
"The quad is a glorified torque shift." Not even close to the truth.
G/MAN
07-30-2007 13:51:22
 Re: Deere engineers turning over in graves in reply to msb, 07-29-2007 10:18:30
I'd say that they are two different designs made to do the same thing, and are fairly similar in overall function, but not in operation. Deere used their powershift experience and figured out that to keep the thing in one piece, you'd have to make it impossible to slip and make sure it was either "in" or "out". Simple solution - pilot-operated shifting using hydraulic oil to control the shifting action. Doesn't matter how slowly you try to bump the lever, once it hits a certain point the hydraulics take over and the shift is made at the same speed it would be if the lever was banged right over. And of course Deere was smart enough to build the Perma-Clutch, also. Guess it didn't matter much that IH used a dry clutch. If the T-A went out you could do the clutch while you were there and vice versa. The sad fact is that IH's engineering and innovation was a far distant second place to Deere from the mid-to late 50s until they went under.
msb
07-29-2007 19:38:28
Sorry if I offend anyone, but the statement was close to what an engineer said at the 4430/4630 service school I attened in 1973 when someone compared the quad range to an IH torque amplifier.We were VERY quickly informed that there was no resemblence in design or reliability to an IH torque amplifier.
jddriver
07-29-2007 11:48:25
Your response is exactly why there has been an exodous from this board.There is an overwhelming supply of info here.I have had over 100 of these units apart and they are less than reliable.TThey have made my shop 1000's of dollars.The two speed is a hydraulic actuated clutch pack that engages a 3 gear planettary and the common problem is that the case just breaks.The new six bolt design is a TON better but in my opinion they are still less than desirable.But I will defer to you
rexhellwig
07-29-2007 12:36:58
 Re: Deere engineers turning over in graves in reply to jddriver, 07-29-2007 11:48:25
For what it's worth. I've been working on 30 series tractors for over 27 years. I have yet to see a pinion carrier or a clutch drum "just break". I won't even sell a guy a new six bolt two speed assembly unless he requests it or unless the seal rings have worn into the brake housing, etc.
The usual updates are of course:
1- Installing new rubber shank carrier bolts. {I've seen a handful of the early non-rubber bolts back out and cause $$$}
2- Install the new brake piston with the two "sealing assist holes".
We've had some customers greatly abuse these things over the years- Fueling to 180 horse - Adding lots and lots of weights. Rocking in mud.- Breaking parts in general, but never physically breaking the two speed housings or carrier.
What in the world are your customers doing to achieve this feat and does anyone have any similar reports?
Bob
07-29-2007 13:05:33
 Re: Deere engineers turning over in graves in reply to rexhellwig, 07-29-2007 12:36:58
Amen to those comments!
wilamayb
07-29-2007 12:28:18
So somebody fill me in here. What is a "torque shift", and what does it have in common with the quad range? Just wondering for my own common knowledge...
Bob
07-29-2007 13:05:07
 torque shift defined in reply to wilamayb, 07-29-2007 12:28:18
"torque shift" is a form of "if you can't dazzle 'em with brilliance, baffle 'em with "B.S.".
Bob
07-29-2007 10:49:33
I wonder where he came up with THAT one???
