4430 a good buy?
paulp
07-29-2007 06:45:17
Hey I;m looking at a 4430 diesel, cab, air, quad, 7500 hrs, the guy spent 12,000 or so he says on trans, clutch and motor, seems to run nice and stuff, he;s asking $13, 500 CDN for it. I've only run IH in the past, like the 86 series, the 88 series and one 2+2 IH 4wd, but I've heard that these 4430's are one great tractor if hard on fuel. I'm in the market gardening business, so it would be put on a scuffler/sprayer doing light work and plowing in the fall. I'm mostly looking at it since it has the fuel tank in the front so it's easier to see out eh back with a rear mount scuffler, while the 86 and 88 series IH have fuel tank in thew back which makes it a pain to see over it. Any of you guys that have experience with this model of tractor feel free to share your stories, either good, bad or neutral, the tractors about 3 hrs away so I need a bit of feedback before I drive all that distance. It would be my first deere, I've only run IH before b/c they were cheaper to initially buy and I'm a young guy starting out and don't have a huge wallet ;)
Thanks in advance for any info/tales you can give me
Paul
wilamayb
07-30-2007 15:44:10
 Re: Deere engineers turning over in graves in reply to paulp, 07-29-2007 06:45:17
Alright now GMAN dont be so hard on poor old IH..... The 06's were not so bad so long as you threw away the shifters and frontend... Oh but wait you gotta have those dont you.third party image
paulp
07-30-2007 07:13:14
 Re: 4430 a good buy? in reply to paulp, 07-29-2007 06:45:17
Thanks for all of the info btw to those that asked its a 2 stick 16 speed transmission and I'm not sure of the year, I have to go see it myself and drive it around and I'll definitely hook it up to something and run it around. Just an interesting note, when I ran IH's I never used the torque amplifier only the gears since I didn't want it to go in it and its about 5 grand to fix it ;)
Paul
Tx Jim
07-30-2007 04:44:02
 Re: Shaking? in reply to buickanddeere, 07-29-2007 06:45:17
Will as Bob stated cab mounts can cause vibration but tire tread at certain speeds can also cause vibration. Also JD recommends changing torshion dampner at every 4500 hrs operation. I've been around quad-range tranny's since they were introduced and I think whomever thinks the Quad-range is not a good tranny is inhaling more than "diesel smoke". Tx Jim
Hoss in Maine
07-29-2007 14:37:52
They dont make em like they used to do they? Throw them together with a little more bling and fancy named dodads and ship them out the door.Its just like the new car and trucks,who amoung you can work on any of this new crap? Later Hoss
wilamayb
07-29-2007 16:57:57
 Re: 4430 a good buy? in reply to Hoss in Maine, 07-29-2007 14:37:52
I work on it everyday. Its really no harder to work on than this old junk that we love so much, plus it has the ability to tell you what's wrong with it.
Old machines are like babies. They cry when something is wrong but cant tell you what. New machines have the ability to talk. It really works out quite well if you have the tools to use the electronics. Deere only allows dealers to have Service Advisor which is the software to obtain diagnostic information.
I would dare to say that the new machines being made are as durable if not more than the old ones. They certainly reach much higher levels of efficiency.
The only folks that have not been able to keep up are the engine folks in Waterloo. Outside of fuel efficiency improvements JD doesnt seem to be too interested in engines. Maybe they are too busy with emission standads to work on the actual mechanics of the engine?
rexhellwig
07-29-2007 12:02:06
The only thing I see that concerns me is this:
When did this tractor get 12,000 spent on it? Was it very recently? If the previous owner knew he was about to retire or buy another tractor, why would he invest an amount roughly equal to the machine's value if he had no intention of keeping it? He would have been far ahead to part it out or scrap it.
Before you go spend any money, you need to ask a few more questions. Who has done all of repair work? Are they competent? Some shops can spend 12K with little if any improvement. Maybe someone knows something you don't --- yet.
If the previous owner or the repair shop seem vague or unusually ignorant about what repairs have been done and when, find another tractor.
A great man once said, "Trust, but verify."
JMS/MN
07-29-2007 10:52:43
They are an excellent tractor-one of the several extremely popular JDs- like the 4020, 4440. Early ones did have some rear end update, but mine is a 1974, light rear end- has 10700 hrs, first engine, trans, rear end. Had an 'underhaul' (crank and main bearings) at 8700 hrs. Only internal engine work. Power Shift. Bit pokey to start in cold weather compared to other models. Plowing with 5-18, chopping hay, runs about 6 gph. AC lines replaced at about 13 years, just like other Deeres. Mine is for sale only since it's excess after quitting dairy. Triple remotes, 20.8 rears and duals. Dyno's 137hp.
msb
07-29-2007 10:18:30
"The quad is a glorified torque shift." Not even close to the truth.
G/MAN
07-30-2007 13:51:22
 Re: Deere engineers turning over in graves in reply to msb, 07-29-2007 10:18:30
I'd say that they are two different designs made to do the same thing, and are fairly similar in overall function, but not in operation. Deere used their powershift experience and figured out that to keep the thing in one piece, you'd have to make it impossible to slip and make sure it was either "in" or "out". Simple solution - pilot-operated shifting using hydraulic oil to control the shifting action. Doesn't matter how slowly you try to bump the lever, once it hits a certain point the hydraulics take over and the shift is made at the same speed it would be if the lever was banged right over. And of course Deere was smart enough to build the Perma-Clutch, also. Guess it didn't matter much that IH used a dry clutch. If the T-A went out you could do the clutch while you were there and vice versa. The sad fact is that IH's engineering and innovation was a far distant second place to Deere from the mid-to late 50s until they went under.
msb
07-29-2007 19:38:28
Sorry if I offend anyone, but the statement was close to what an engineer said at the 4430/4630 service school I attened in 1973 when someone compared the quad range to an IH torque amplifier.We were VERY quickly informed that there was no resemblence in design or reliability to an IH torque amplifier.
jddriver
07-29-2007 11:48:25
Your response is exactly why there has been an exodous from this board.There is an overwhelming supply of info here.I have had over 100 of these units apart and they are less than reliable.TThey have made my shop 1000's of dollars.The two speed is a hydraulic actuated clutch pack that engages a 3 gear planettary and the common problem is that the case just breaks.The new six bolt design is a TON better but in my opinion they are still less than desirable.But I will defer to you
rexhellwig
07-29-2007 12:36:58
 Re: Deere engineers turning over in graves in reply to jddriver, 07-29-2007 11:48:25
For what it's worth. I've been working on 30 series tractors for over 27 years. I have yet to see a pinion carrier or a clutch drum "just break". I won't even sell a guy a new six bolt two speed assembly unless he requests it or unless the seal rings have worn into the brake housing, etc.
The usual updates are of course:
1- Installing new rubber shank carrier bolts. {I've seen a handful of the early non-rubber bolts back out and cause $$$}
2- Install the new brake piston with the two "sealing assist holes".
We've had some customers greatly abuse these things over the years- Fueling to 180 horse - Adding lots and lots of weights. Rocking in mud.- Breaking parts in general, but never physically breaking the two speed housings or carrier.
What in the world are your customers doing to achieve this feat and does anyone have any similar reports?
Bob
07-29-2007 13:05:33
 Re: Deere engineers turning over in graves in reply to rexhellwig, 07-29-2007 12:36:58
Amen to those comments!
wilamayb
07-29-2007 12:28:18
So somebody fill me in here. What is a "torque shift", and what does it have in common with the quad range? Just wondering for my own common knowledge...
Bob
07-29-2007 13:05:07
 torque shift defined in reply to wilamayb, 07-29-2007 12:28:18
"torque shift" is a form of "if you can't dazzle 'em with brilliance, baffle 'em with "B.S.".
Bob
07-29-2007 10:49:33
I wonder where he came up with THAT one???
Will Herring
07-29-2007 08:22:54
We have a 4430 at work that I have used, and I have to say that it is a very nice tractor. It has a lot of pulling power. The problems it has, is that it leaks hydralic fluid quite a bit (as well as having a squeaky pump), and the air conditioning doesn't work in it. Nothing that opening the windows and bungee-cording the door open doesn't fix.
But it has the two stick quad range (16 different speeds) and 2 SCV. If you don't have it throttled just right, the tractor will shake, and so will both shifters. The inner stick that goes between 1, 2, N, 3, and 4 is very wobbly and is a bit too easy to knock between gears. But it is a really nice tractor, it's been fairly low maintenance so far.
Bob
07-29-2007 13:08:53
 Shaking? in reply to Will Herring, 07-29-2007 08:22:54
"If you don't have it throttled just right, the tractor will shake, and so will both shifters."
NOT normal. SOMETHING is out of balance... first, check out the harmonic damper for "wobble".
Better find the problem before something breaks!
Will Herring
07-29-2007 13:47:26
 Re: Shaking? in reply to Bob, 07-29-2007 13:08:53
Really? That's not good. If you just pop it in like B3 at 1000 RPM, it will just shake as you drive across, and both shifters will shake a little. Is something dangerously badly worn? Which part of the tractor needs torn into to check this? D:
Bob
07-29-2007 13:54:29
 Re: Shaking? in reply to Will Herring, 07-29-2007 13:47:26
do the levers just flop when the 2-speed shifts, or shake continuously at certain speeds?
I have seen the crankshaft torsional dampers get so bad, (wobble) that the tranny levers will shake continuously at certain speeds.
Also, bad cab mounts will allow the SGB to flop around in relation to the tractor, making the shift levers flop.
Will Herring
07-29-2007 14:01:29
 Re: Shaking? in reply to Bob, 07-29-2007 13:54:29
Well... The A-D range shifter is pretty solid, but the 1-4 shifter is pretty lose between 1-2 and 3-4 respectively. I mean, it doesn't jump between gears on its own, but it just kind of hangs in the middle when you are going, and then when the speed isn't set right it just shakes and flops. It's hard to explain, but I'll have to examine it more this week to see if I can figure it out.
JD@Antique Acres
07-29-2007 08:11:25
One thing to add is, and I don't know if you are in Canada, but the 30 series could be buggers to start in cold weather.
jddriver
07-29-2007 08:09:55
MAKE DARN SURE it is later than 1976.The quad is a glorified torque shift.If under a heavy load do not shift it with out lighting the load.Our 4430 under heavy load is about 6.5 gph.That price is a little steep.We bought a nice 4640 in york Nebraska for 15500 with 6 new tires and fully weighted.I hate quad range trans they have my shop alot of $$Try to find out if the two speed planettray is a 6 bolt design.If not just walk away.because it will break and you will spend 3-5000 to fix it.
jddriver
07-29-2007 08:09:55
jdmaninsd
07-29-2007 13:41:39
 Re: 4430 a good buy? in reply to jddriver, 07-29-2007 08:09:55
if you think quad is glorified torque you dont know much about eather one ih tork made shops more money than any other unit on any tractor you a eather full of bs or you have the worest bunch of operators the contry jd man
Bob
07-29-2007 13:47:02
 Re: 4430 a good buy? in reply to jdmaninsd, 07-29-2007 13:41:39
If a Deere 2-speed needs work, ONE split of the tractor, between the engine and clutch housing, is needed.
With an IH, to repair the hydraulic TA, the tractor must be split TWICE, once at the clutch housing, and again between the clutch housing and the transmission case. Then, the lower tranny shaft must be pulled, and the gears "dropped" to allow removal of the TA. FUN!
4010 puller
07-29-2007 07:18:17
Paul:
Check to see if the air works, most do not by now and take a little money to get working. Are the tires good? Does the man have the receipts for all the work he did? They are a great tractor if taken care of but if neglected and have a lot of hours you could have some hydraulic problems. Run it around and check the shifting of the tranny, check the power steering and brakes, the pto, and even tell him you want to hook something up to the hydraulics such as a haybine or disk and see that it lifts strong and doesnt chatter and shake. I had heard that a few of the first year early models had some rear end trouble but dont know this for a fact, I"ve never had any experience with it myself anyway. Which tranny is in it, the single stick 8 speed power shift, or the twin stick 16 speed quad range?
