1947 A Oil pressure
craig reavley
07-07-2007 07:18:13
I started my A yesterday, and it has low oil pressure. I have read multiple posts on this topic, and plan to replace the thin gasket on the pump first.I need to check the screen in the crankcase and see if it is plugged and check the drive shaft square bushing thing. I was also told to turn up the oil pressure on the left side of the tractor there is an adjusting screw behind a square cap. What are the thoughts on adjusting the pressure. The gauge is brand new the needle moves from the peg to low when tractor starts
Mike M
07-07-2007 09:28:49
 Re: 1947 A Oil pressure in reply to craig reavley, 07-07-2007 07:18:13
I think you will find that agjustment on the RH side of the tractor under the belt pulley area . There is a pipe plug you remove and the adjustment screw is right there. Clockwise turns it up.
F-I-T
07-07-2007 09:18:46
The other guys have you covered, but I for one, would not head towards the thin gasket on the pump. Unless that is leaking, they seldom go bad. It is not atypical to have to adjust the oil pump by-pass pressure valve, so once you are sure you have a good gauge to work with, just bump it up to where you are happy. If you drain the oil and remove the top cover, you can have a good view of the screen. I use a little air pressure wand with a siphon pick up to jet diesel fuel or Kerosene into and around the pump. The horizontal crankcase design really lends itself to a quick and thorough clean up. Don't let adjusting that oil pressure be a big deal. There are several posts concerning it in the search-able archives. Here's one:
Will P
07-07-2007 09:01:57
Did the old gauge read nice oil pressure? New oil pressure gauges will read low. They just can't make them right. If you have the old one. Put back on and see if it reads good.
Will
MSM
07-07-2007 09:01:20
Assuming the oil and filter is clean, not gasoline diluted,and the proper viscosity,it may pay to check the pressure with a master guage.Some of the aftermarket oil guages are not calibrated properly for the application. Some may say low,but are actually reading 25# of oil pressure,while others may read low while reading 5# of oil pressure.
Check and see what your actual pressure is before adjusting it up to meet the new guage,too much can be as bad as too little.
