Drop in oil pressure - Model H
davr101
06-30-2007 16:09:51
I recently changed the oil in my 1939 JD H for the first time since I owned it (about six months). I used Shell Rotella 30 wt and a JD filter. The tractor used to hold oil pressure between medium and high even at the lowest idle. It now runs at Low or a little below even with some RPMs. Should I have used a different wt of oil? Also the oil filter was hard to center since the hole in the filter where it goes over the rod was much bigger than the rod itself. Could an uncentered oil filter cause a drop in oil pressure? Any advice will be greatly appreciated.
Dave
davr101
07-03-2007 14:05:52
 Re: Drop in oil pressure - Model H in reply to davr101, 06-30-2007 16:09:51
I changed the oil to straight 40 wt and the oil pressure returned to what it was before the problems started. Thanks to all of you who responded.
Dave
F-I-T
06-30-2007 19:01:56
This is a full-flow lubrication system, which means that every drop of oil goes through the filter, then to the pump, before it goes to the engine. Since this is the first time oil change, you don't know what the weight was, other than to judge the viscosity as it drained. Anyway, you didn't say how dirty or stringy it was, if it had pieces of RTV run out with it, or how much sludge, if any hit the bucket. I say this because the system will pump fine and deliver great pressure whether you have a filter in there or not. So unless you really have the filter kicked to one side, I doubt that its position will affect the oil flow, pressure, or delivery.
Now if you over-tightened the nut (1) on the cap, you could have broken the pump manifold that is atop of the oil filter can, which can cause a quick drop in pressure, or you could have just about broken it, instead deforming the top of the can causing a leak between the can top and the manifold gasket. Either way, that would mean you will have to go in through the top and check things out.
BUT FIRST...why not try some easy things that don't cost a cent?
When you change oil, you always stand the chance of having the fresh oil wash some old sludge loose and that can get stuck in the pressure relief poppet (37). A string of RTV is a classic for this. I have even seen a piece of corn cob hang a poppet open because it got inside the can during a change on a windy October day, and it went through the pump and lodged under the poppet, lifting it off of its seat, and so the pump vented the majority of its flow to the crankcase instead of it going up the pipes.
I would run the engine and try turning the adjuster (42) in a click at a time and see if the pressure improves to the point that you recognize as "Normal". Run it a bit there and if it doesn't jump around, or fall to the peg (other than the normal amount it will fall as it warms), you can choose to run it like that but keep an eye on things. This sometimes works, but if there is a piece of debris that is trapped under the poppet, no amount of spring assist (40) will allow it to re-seat, so if you cannot increase the pressure by turning in the by-pass pressure adjuster, you probably have a chunk of debris holding it off of its seat.
Now what I do is to warm the engine, and while it is running, I turn the adjuster screw (42) out until it is just about all the way out. You might want to practice this maneuver, engine off, and count how far it takes to get it nearly full out. This will relieve the spring assist (40) pressure on the leaf spring poppet and if there is any debris under the poppet, many times it blows out. When it puffs out, the pressure might fall to the peg, but if you just start turning the screw back in and stop when the pressure is "Normal" for you, you might avoid opening it up. I have done this on probably every old Deere I have owned or worked on, and many times it clears the poppet and pressure returns when finally adjusted. Also, the oil filter being difficult could indicate that your '39, which came originally with a spun-brass Purolator filter, has not been updated. If you get the oil pressure back up to where it needs to be, I would some day take the filter cover off, remove the filter and make sure that you have the proper tube (11) with the large washer, along with the other parts (6,7,8,9) called out for the conversion on page 4 of parts catalog PC304. This is what helps guide the filter into position and it helps make the filter fill and flow correctly.
Frank
third party image
davr101
07-04-2007 13:59:27
 Re: Drop in oil pressure - Model H in reply to F-I-T, 06-30-2007 19:01:56
Frank, thanks so much for all the useful information. I don't know if you saw my other post, but I ended up putting 40 wt oil in the H and the problem was solved. I tried backing out the pressure adjuster, and guess what. I went too far and dropped it in the crankcase. It was hard to fish out and get back in, but I did it.
Anyway, thanks for your help. These discussion boards are great. Hopefully I can help someone else out soon.
Dave
Kent Petersen
07-01-2007 18:49:46
Frank i think you miss spook the pump picks up the oil and moves it thru oil filter and back to upper part of pump and out thur the lines on a Model H Kent
F-i-T
07-01-2007 19:38:51
 Re: Drop in oil pressure - Model H in reply to Kent Petersen, 07-01-2007 18:49:46
Yes, I meant from the pump through the filter. But they can and do still get an occasional slug of crud or debris under the pressure relief poppet.
davr101
06-30-2007 22:59:04
Thanks. That was very useful information. I will check these things out. There was no sludge when I changed the oil. It was just very dark.
Dave
P Browning
06-30-2007 17:05:17
davr101 -- From page 128 of the John Deere H Restoration Guide, we have the following paragraph:
"Question #12. What are possible causes for sudden lower oil pressure, or for none at all? A distorted oil filter body is one cause. Distortion is usually the result of excessive torque applied to the lower cover nut. "Normal" tightening is sufficient. Do not over-tighten it! If leaks persist, renew the rubber gasket. A second cause could be that one of the oil lines leading from the pump wasn't fully installed during reassembly. A third likely cause is that the home-made pump gasket (in substitution for B246R) is too thick allowing oil to "slip by" the pumping gears."
My fear here is that you may have damaged the oil filter body by applying far too much torque. I do not see where you changed the A519R (rubber) oil filter gasket. My bet is that the old one is hard as the Rock of Gibralter, and it's nearly impossible to have no oil leakage with normal tightening of the oil filter cap assembly nut.
Drop me an email if you want some more data on how to recover. (PatB)
