BBQ grill
F-I-T
06-18-2007 08:32:43
If you are going to disassemble to clean and rebuild anuway, remove everything that will come off (float, needle, screen, bowl, throttle/chocke shafts,etc.) and lay it on a bed of charcoal. Let it heat, then cool down. The ash will act as a dry soap lube, and the heat up/cooldown cycle almost always (I've never had it fail me) works to loosen everything that needs to be moveable. It saves you the time of standing there heating the body too fast in one spot.
Frank
