1948 JD A Carb needles stuck
GeorgiaHayFarmer
06-18-2007 07:45:35
Fella's,
What is the best way to get my load and idle needles out of a DLTX 71 carb. I have two carbs that have been sitting and both needles are stuck to where they will not turn. Any ideas?
Scott
machinery-man
06-18-2007 08:51:44
 Re: 1948 JD A Carb needles stuck in reply to GeorgiaHayFarmer, 06-18-2007 07:45:35
I like the charcoal method the best.. Be sure to remove all the brass....
F-I-T
06-18-2007 08:56:59
 Re: 1948 JD A Carb needles stuck in reply to machinery-man, 06-18-2007 08:51:44
It won't hurt the brass because it never gets that hot. Getting the brass plugs to come out is the main reason I use the BBQ grill process. Why fight 'em?
Remove the float if you want to save it because it might melt solder and the air will bulge the float. Take off any gaskets that you don't want to burn. The brass plugs will comne out after the cool down, and the generally the center nozzle will be easier to slide hammer out as well.
Frank
F-I-T
06-18-2007 08:32:43
 BBQ grill in reply to GeorgiaHayFarmer, 06-18-2007 07:45:35
If you are going to disassemble to clean and rebuild anuway, remove everything that will come off (float, needle, screen, bowl, throttle/chocke shafts,etc.) and lay it on a bed of charcoal. Let it heat, then cool down. The ash will act as a dry soap lube, and the heat up/cooldown cycle almost always (I've never had it fail me) works to loosen everything that needs to be moveable. It saves you the time of standing there heating the body too fast in one spot.
Frank
Mike M
06-18-2007 07:59:03
Take apart what you can and then soak them in carb. cleaner for a day. If they then won't move it is rust and not varnish holding them. At this point you can use some heat to loosen them up.
JD@Antique Acres
06-18-2007 07:56:45
I use heat. Take it slow and don't force them. Sometimes the needle is froze in the cast also. Be careful here as you don't want to ruin the needle. It may take a few cycles, add a little penetrating oil in between.
GeorgiaHayFarmer
06-18-2007 08:12:17
 Re: 1948 JD A Carb needles stuck in reply to JD@Antique Acres, 06-18-2007 07:56:45
I'll try to use some heat and oil after carb cleaner and see what happens. The brass nut on one of them will not come off. I have used heat, soaked in kerosene, pb blaster, and light tapping. It will not come off. You fellas have any suggestions? I bought a new brass nut just in case I have to resort to the carbide bit in the dremel tool. I would like to save the nut and do it right before I destroy anything. I appreciate the advice thus far.
Scott
JD@Antique Acres
06-18-2007 10:45:56
 Re: 1948 JD A Carb needles stuck in reply to GeorgiaHayFarmer, 06-18-2007 08:12:17
The brass nut is cheap compared to ruined threads or a broken stem. Be careful if it is hard to get off.
Mike M
06-18-2007 10:38:43
Did you use heat from a propane torch or an acetylene one ? a propane one isn't hot enough fast enough and you will just waste your time.
