Gas to diesel?
jdemaris
12-01-2006 11:50:03
I don't believe the B-diesel story for a minute. If they were to try it, I suspect it would require an entirely different engine to run and hold together on compression-ignition - considering the state of technology of a B gas engine. But - about what you said in regard to the Oldsmobile designed 350 diesel. The initial prototype engines were of MUCH better quality than the production engines that failed miserably. The GM bean-counters did a lot of cost-cutting on the production run of engines. By the time the class-action law-suits were over, GM had beefed up the engines with the newer DX blocks, roller cams, better cranks, high nickel blocks, etc. and they were almost back to the quality of the original prototypes. I think there have bee many sucessful diesel engines, tractors and pickup trucks, that got their start on gas-engine formats. IH stated that the 6.9 and 7.3 diesel was based on an earlier gas engine -but of course was changed and beefed up in many ways. They are a very good engine. I read that most of the major ag. tractor companies reworked existing gas engines to run on diesel after the rotary injection pump became available. Before that, injection pumps were too large and expensive. Vernon Roosa invented the little rotary pump that was first used on Hercules diesels in Ford trucks and Cletrac dozers early 50s - and that Roosa - now Stanadyne pump is what started the big changeover to diesel.
B-maniac
12-01-2006 19:33:14
 Re: Gas to diesel? in reply to jdemaris, 12-01-2006 11:50:03
Running on diesel fuel and BEING a diesel are two completely different things. As to the claim , anybody can cobble up anything and call it what they please.
