Very rare Deere
msb
12-01-2006 08:57:22
A neighbor told about someone finding a Deere diesel tractor in Minnesota of which there were only 17 built.One known to be in Ohio and this one now in Oklahoma. Said he thought it was a B diesel.Was he telling a tale or what? If this is true then it belongs in East Moline.
machinery-man
12-02-2006 13:37:38
 Re: Very rare Deere in reply to msb, 12-01-2006 08:57:22
There is no bs on the diesel. I saw the tractor...I thought it was a 50 but could have been a B...100% diesel. If you can make a 730/830 diesel what would be the problem on any of the others.
New-Gen
12-02-2006 05:18:05
Sounds a little on the same lines as the guy who grafted the rear half of an IH 300 to the front half of an H and had decals made proclaiming it to be a one of a kind experemental HTA. I actually saw this one, but also heard of somebody who paired up a late 4020 to a 4320 and called it the one and only 4320 powershift...
50LPJD
12-01-2006 20:34:29
I KNOW A GUY IN ODON INDIANA,THAT CAN AND HAS BUILT SOME B'S TO RUN ON DIESEL.IT HAS INJECTERS AND A PUMP.HE IS THE MAN TO WORK ON DIESELS.HE IS GOD TO SOME PEOPLE..EVER SEEN THE 830 PULLER.. WOW!!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! HE MAKES HIS OWN HEADS AND BLOCKS.
Will P
12-01-2006 20:23:24
There is a guy in my hometown in SE wi that has a B diesel. He made it himself.
Will P
msb
12-01-2006 20:23:18
Neglected to say the guy said it had a pony motor to start it.I'll talk to him again and ask more questions.He said it was a Deere creation, not a cobble job. He wasn't certain it was a B model.I am wondering if it is a distilate model BO or something like that ,but that would exclude having a true pony motor application.
buickanddeere
12-01-2006 21:32:51
 Re: Very rare Deere in reply to msb, 12-01-2006 20:23:18
An old wives tale mixed with lots of B.S.
D-Man
12-02-2006 11:12:38
 Re: Very rare Deere in reply to buickanddeere, 12-01-2006 21:32:51
Anything is possible to the gifted.
farmerboy
12-01-2006 15:32:16
I'm gonna go out to a friends place near me and snap some pics of a stripped "B" he has an post it on here. The engine is gone but someone put a "Use Diesel Only" sticker on the hood. Coulda been a joke sticker, I know. Maybe there'll be enough left to glean some info on whether or not it was a "Diesel "B".
Also, I have the JR Hobbs book " The JD Styled letter series - 1939-1952" printed by Green Magazine. It speaks of John Jones of Odon, IN who has built diesel "B"s. They have 4430 pistons and seriously reworked Oliver injection pumps.
55 50
12-01-2006 20:52:53
 Re: Very rare Deere in reply to farmerboy, 12-01-2006 15:32:16
I just looked back through my photos of the EXPO where I saw the tractor I mentioned earlier.
I have three photos of this tractor. It's a 1944 "B". The sign on it says:
John Deere 1944 B
Converted to diesel
Built September 1995
Ser# 1004
John and Bonnie Jones
Odon, Indiana
It has an injection pump attached where the mag or distributor was. Two fuel filters on the right side of the block. Injector lines enter into the front surface of the valve cover. Also an electric starter plainly shows beween the flywheel and the upper sheet metal. The block and head look the same size as on a normal "B".
Anyone wanting further info could contact Mr Jones. Does anyone here live in proximity of Odon, IN?
55 50
12-01-2006 21:19:12
 Re: Very rare Deere in reply to 55 50, 12-01-2006 20:52:53
I should have added that there is no sign of a plugged hole where the spark plugs were so that probably confirms what others have said that Mr. Jones makes his own heads and blocks.
RalphinWI
12-01-2006 15:22:11
The two fuel models would run on diesel fuel, if you kept the water temperature near the boiling point, i.e. 190+. I mix some gas with #2 for my D. There were some B's (garden tractors?) with very low production numbers. Since they were unstyled they were also 2 fuel tractors, i.e. start on gas and run on distillate, which I think would approximate #1 fuel oil. Converting one of these to run as a diesel would give new meaning to the phrase, "leaky head gasket". The required cranking pressure for a diesel is in excess of 300 psi. The two fuels were about 80psi(?) while the gas A's were 110psi. In addition to finding more space for head bolts and fuel injectors one would have to do a major rework of the starting system. It certainly wouldn't be a hand cranker.
PeterE
12-01-2006 14:42:15
I don't believe the "diesel B" story, but...
you could probably run an all-fuel on diesel, if it was really hot. A lot of companies made spark-ignition diesel engines in the 1930s and 40s. Converting to a compression-ignition diesel would be a huge job, as others have already noted.
machinery-man
12-01-2006 11:23:37
I saw a 50 converted to diesel at the Elnora, Ind show some years ago. In viewing it, I could tell it was a major job to produce. As I recall it had the injector pump running off the governor shaft, same location as mag or distributor. It appears the owner must have ran his own machine shop. Its obvious if you could get the P.S.I. up to a sufficent amount develope a fuel injection arrangement the diesel is no problem. I believe the crank was standard. Can"t remember what type of decompression arrangement was on the tractor maybe it was a pitcock arrangement.
fixerupper
12-01-2006 10:56:11
Kinda hard to swallow this one. When Deere started tinkering with diesel back in the 40's they tried converting a D to diesel and it didn't work. Jim
RalphinWI
12-01-2006 10:11:39
old
12-01-2006 21:13:42
 Re: Very rare Deere in reply to RalphinWI, 12-01-2006 10:11:39
They where call ALL Fuel, I.E. they would start on gas and then when warmed up could be run on kero, diesel or disitle. I've had a 1935 JD-B since some time in the 80s and have run it on diesel/gas mix since it runs better and also run it on kero. The manual explains it better then what I just did, and yes I have the manual that came with it way back in 1935
55 50
12-01-2006 09:07:31
I recall seeing a "B" diesel at a 2 cyl EXPO several years ago. I don"t recall all the details and didn"t talk to the owner but assumed it was a creation of the owner. Maybe it was even a fake just to attract attention! Some really weird (maybe I should say "really unusual") things show up at the EXPOs!
Kurt_JDB
12-01-2006 09:36:41
 Re: Very rare Deere in reply to 55 50, 12-01-2006 09:07:31
Seems like I heard that Deere or someone else developed a conversion kit for the two cyliner gas tractors so they would run on diesel.
Kurt
Chuck730DSE
12-01-2006 10:06:57
 Re: Very rare Deere in reply to Kurt_JDB, 12-01-2006 09:36:41
Many things are possible, but I do not believe a gas Waterloo engine would convert to diesel with any reliability. The US car makers tried to pull that one off on us back in the 1970s and 1980s. They took a gasoline block and converted it to diesel. If any of you owned one, you can tell us how well that worked out for you. Some did OK but many had issues, as the mains are not strong enough to handle the increased torque and loads of a diesel burner.
I would love to see documentation if JD ever converted a B to diesel.
Some of you have seen V8 engines fitted in to Waterloos, especially that JD A. It works but it was never produced that way for distribution to my knowledge.
jdemaris
12-01-2006 11:50:03
 Gas to diesel? in reply to Chuck730DSE, 12-01-2006 10:06:57
I don't believe the B-diesel story for a minute. If they were to try it, I suspect it would require an entirely different engine to run and hold together on compression-ignition - considering the state of technology of a B gas engine. But - about what you said in regard to the Oldsmobile designed 350 diesel. The initial prototype engines were of MUCH better quality than the production engines that failed miserably. The GM bean-counters did a lot of cost-cutting on the production run of engines. By the time the class-action law-suits were over, GM had beefed up the engines with the newer DX blocks, roller cams, better cranks, high nickel blocks, etc. and they were almost back to the quality of the original prototypes. I think there have bee many sucessful diesel engines, tractors and pickup trucks, that got their start on gas-engine formats. IH stated that the 6.9 and 7.3 diesel was based on an earlier gas engine -but of course was changed and beefed up in many ways. They are a very good engine. I read that most of the major ag. tractor companies reworked existing gas engines to run on diesel after the rotary injection pump became available. Before that, injection pumps were too large and expensive. Vernon Roosa invented the little rotary pump that was first used on Hercules diesels in Ford trucks and Cletrac dozers early 50s - and that Roosa - now Stanadyne pump is what started the big changeover to diesel.
B-maniac
12-01-2006 19:33:14
 Re: Gas to diesel? in reply to jdemaris, 12-01-2006 11:50:03
Running on diesel fuel and BEING a diesel are two completely different things. As to the claim , anybody can cobble up anything and call it what they please.
