#35 or #36 Deere ripper
jdemaris
11-20-2006 05:54:27
They are usually available aftermarket from many places. The stuff from Deere was aftermarket anyway. Your ripper should be a Deere #35 or #36 rear ripper, used on 1010s, 350s, 2010s, and 450s. Deere #s are - for the shank U15516, and the replaceble teeth on the end - U15517U. Also, each shank, originally had a little lock you hammered in - #U15518U. They usually fall out and get lost. Also - in hard ground - five shanks is usually too much for a 350 - three is about all it will handle well - unless you've got soft ground. I bought my last set last year from H&L tooth in Oklahoma. 800-858-6684. With their part numbers, shanks are HL-50947 and teeth are HL-6Y-5230. I made my own method of locking them in, works much better than what was original. Each of mine has a hitch-pin. Their website is at: Link If, for some reason - they are not carried anymore - I might sell you two assemblies. That because I bought five - and later found out my crawler cannot pull them all. So, I only run three - and two new ones left over.
