JD 350 rake tines for the back of my dozer
Michael Turner
11-19-2006 20:55:18
I hope someone can help me to find two tines for the back of my dozer, it has five holes for five tines, I have one in the middle, i need 2 more for the out side of the unit, any help will be appriciated
Thanks
Mike
jdemaris
11-20-2006 05:54:27
 #35 or #36 Deere ripper in reply to Michael Turner, 11-19-2006 20:55:18
They are usually available aftermarket from many places. The stuff from Deere was aftermarket anyway. Your ripper should be a Deere #35 or #36 rear ripper, used on 1010s, 350s, 2010s, and 450s. Deere #s are - for the shank U15516, and the replaceble teeth on the end - U15517U. Also, each shank, originally had a little lock you hammered in - #U15518U. They usually fall out and get lost. Also - in hard ground - five shanks is usually too much for a 350 - three is about all it will handle well - unless you've got soft ground. I bought my last set last year from H&L tooth in Oklahoma. 800-858-6684. With their part numbers, shanks are HL-50947 and teeth are HL-6Y-5230. I made my own method of locking them in, works much better than what was original. Each of mine has a hitch-pin. Their website is at: Link If, for some reason - they are not carried anymore - I might sell you two assemblies. That because I bought five - and later found out my crawler cannot pull them all. So, I only run three - and two new ones left over.
old
11-19-2006 21:08:32
 Re: JD 350 rake tines for the back of my dozer in reply to Michael Turner, 11-19-2006 20:55:18
Can't help with finding them but can help by letting you know the proper name for them. They are called rippers, so if you ask at a JD dealer or heavy equipment place for rippers they may be able to help you. I know theres rippers from other brands that will probably work on your machine
CH
11-20-2006 03:43:49
 Re: JD 350 rake tines for the back of my dozer in reply to old, 11-19-2006 21:08:32
The proper name for the tool is Scarifier. Ripper would be slang and what he is looking for are teeth.
old
11-20-2006 09:23:36
 Re: JD 350 rake tines for the back of my dozer in reply to CH, 11-20-2006 03:43:49
Don't know where you are but in this area they are and always have been called rippers, and I did retired from heavy equipment type work and did it for years and I have NEVER ever heard of them call any thing but rippers. Now a Scarifier is a part like ithe ripper but they are on road graders not dozers 2 differant machines and 2 differant names and parts
jdemaris
11-20-2006 06:00:51
 Slang?? in reply to CH, 11-20-2006 03:43:49
I've got my original John Deere owner's manual and parts manual. Deere - officially calls it a Hydraulic Ripper - #35 and #36 - made in the Dubuque Tractor Works. The part that carries the tooth - is called by Deere a "ripper tooth shank", and the tooth on the end is called "replaceable tip." Nowhere in the Deere catalog is the word "scarifier" used - so in this case - I don't think "ripper" is slang.
