123.5 or 127 degrees?
jdemaris
11-12-2006 06:46:38
If you can't get the static timing where you want it - at 14 degrees BTDC - then your engine oil-pump is out of time. The fuel-injection drive slot in the engine oil pump should be 15 degree from parallel with the crankshaft with the V mark towards the block with #1 at TDC of its compression stroke.
You also ought to make sure your fuel injection pump is the orignal and not a later or older and altered 4020 style pump that gets timed differently (TDC instead of 14 before TDC). The original 4010 pump should be a DBGVC631-4F, 11AF, or a 1AJ with the timing marked that is etched on the pump at 123.5 degrees. A 4020 pump would be a 633 of some sort - CBC, JDB, or DB and the timing marked is etched at 127 degrees.
61-4010
11-12-2006 08:57:49
 Re: 123.5 or 127 degrees? in reply to jdemaris, 11-12-2006 06:46:38
Thanks for the details. The Roosa appears to be an original based upon the plate. So it appears that I'm not at 15 degrees. I made a host of changes in this machine....new cam came with the "finer" teeth gear so I had to change the gear on the oil pump and the tach. I suspect that I'm one tooth off.
Thanks for the info! I'll give this a whirl.
