4230 Hydraulics
R. John Johnson
09-26-2006 08:30:51
Hi guys
I would like to get some opinions on a problem I'm having with the hydraulics on my 4230. Everything is fine when cold . After the oil gets good and warm, and I reduce engine speed, the hydraulics (remote first, steering last)get jerky. When they are jerky there is a buzzing or rattling sound at the front of the cab. The warmer the hydraulics get, the faster I have to run it to keep everything OK. By the end of the day I may need 1200 rpm to keep everything ok. I have had one mechanic's opinion that the pump is worn out and needs rebuilding. It works for now, but I want to fix this over winter.
Thanks
John
charlesmacleod
09-27-2006 02:48:35
 Re: 4230 Hydraulics in reply to R. John Johnson, 09-26-2006 08:30:51
Yes check the standby pressure when the oil is hot,should by above 2200 ish also on tickover use the loader and see if pressure is maintained at 1600 by the PCV . PCV is at front right side of rockshaft cover .Stroke control valve sets pressure ,if pressure is weak adjust or renew it,access under pump at front
Glen in TX
09-26-2006 12:34:13
The buzzing noise you describe sounds like could be PCV, pressure control valve problem also. If other hydraulics seem okay and steering and brakes not working well that could be it. The springs can break or get distorted over time and the valves can get worn or scored from crud that gets past filters. Try the filters, screen and oil change first and see what happens.
R. John Johnson
09-27-2006 07:23:41
 Re: 4230 Hydraulics in reply to Glen in TX, 09-26-2006 12:34:13
Ill try to get a reading on pressure. I have a guage with a male and female couler on it that can be installed in line with on a SCV. If I check the pressure as I first activate an already stroked out cylinder this should give me a quick idea of standby pressure.
Glen, in your post you mentioned steering and brakes affected before the SCV's, but it is the other way around. The oil must be quite warm and the engine at its lowest speed before steering is affected. Come to think of it the first motion of the steering wheel is OK, but then it gets jerky.
I'll post back later after changing filter and screen and getting a handle on pressure.
Thanks guys
John
charlesmacleod
09-27-2006 23:43:30
 Re: 4230 Hydraulics in reply to R. John Johnson, 09-27-2006 07:23:41
Please note that if you use the SCV for your pressure reading you will not test the PCV otherwise known as the priority valve as of course it is ahead of the SCV, I supose you should also quick check transmission pump flow, on left side disconnect the pipe to the front pump ,I forget how much in 1 minute , lots anyway.
If all these show nothing then an internal leak in high pressure side becomes a possibility,but at this stage I doubt it , does the oil get very hot?
Glen in TX
09-27-2006 10:04:49
I just wanted you be aware of the PCV under dash since you mentioned a noise from that area. It may be fine but still make some noise there too when you have other hydraulic problems. Starting to see more tractors with age on them having the PCV spring break or valve sticking or O rings gone. Might also need to check relief valve if pressure test doesn't do well. If that sump screen hasn't been cleaned or replaced since you've had it get that done but you will need to drain all the oil to do that or pulling the screen plug will let it all out on you. If that first pump can't get enough oil with screen plugged nothing is going to work right. Old worn brake material and other stuff gets stuck around that screen over time. If it has metal screen you might can clean it but if plastic one just replace it.
Tx Jim
09-26-2006 10:07:41
I suppose you have changed hyd. filter and cleaned sump screen. Have you checked stand-by pressure? Tx Jim
R. John Johnson
09-26-2006 11:19:40
 Re: 4230 Hydraulics in reply to Tx Jim, 09-26-2006 10:07:41
Jim
Hate to admit it, but I never changed the filter or cleaned the screen when I bought it. I could be wrong, but if the pump was being starved for oil by one of these two items, wouldn't the colder, stiffer oil make the problem worse, not better? I have not checked pressure, but when in use on my bale carrier there seems to be not shortage of power on the hydraulics.
John
