JD 4430 steering
Loy S
09-25-2006 08:35:46
The steering on this tractor drifts at times. Also, it turns slow at times as well. Almost like delayed reaction. Any help would be appreciated.
Glen in TX
09-25-2006 18:01:36
 Re: JD 4430 steering in reply to Loy S, 09-25-2006 08:35:46
Any leaks anywhere under dash or under fuel tank and front pump area? Those you can probably fix yourself. Do the remotes and 3 point still work well? If so but brakes and steering don't then might suspect the PCV pressure control valve or otherwise steering cylinder or steering motor problems. Look at some of that and talk it over with your local dealer service manager. Good luck.
Loy S
09-25-2006 18:59:18
 Re: JD 4430 steering in reply to Glen in TX, 09-25-2006 18:01:36
No leaks to speak of. The brakes work but are a bit sensitive. Thanks for the info. Hope it isn"t the steering motor but seems to point in that direction. Loy.
Glen in TX
09-25-2006 21:55:44
 Re: JD 4430 steering in reply to Loy S, 09-25-2006 18:59:18
Stuff can get in the pressure control valve making it stick one way or if there was a air lock or brakes applied real hard once could make it stick wrong way not letting you have equal pressure to brakes and steering. Sometimes the spring breaks or goes bad after time in PCV too. You will usually hear lots of strange noise from PCV valve area too if it's stuck, chattering or spring is bad and not have good steering or brakes yet other hydraulics works fine. PCV job is to keep pressure to steering and brakes in case other hydraulics starts failing.
Loy S
09-26-2006 06:30:42
 Re: JD 4430 steering in reply to Glen in TX, 09-25-2006 21:55:44
Where is the PCV valve located?? I will start there. Thanks Glen. Loy.
Glen in TX
09-26-2006 12:19:28
 Re: JD 4430 steering in reply to Loy S, 09-26-2006 06:30:42
Loy, It's up under the dash, right hand side I believe. 4430 online parts catalog doesn't show it real well so this is pic of one on 4450 with quad range trans. Watch and don't lose any shim washers (4) inside and a service manual should tell you what the length of spring (3) should be or it might tell by looking up the spring part number online at JD parts also. Check the valve (5) for scratches and scoring and bore of valve casting for scoring. Could be slight difference in valve and lines depending on which transmission you have too. I hope it's not the steering motor either or you'll have to take in to shop. Good luck with it. third party image
Loy S
09-26-2006 13:04:18
 Re: JD 4430 steering in reply to Glen in TX, 09-26-2006 12:19:28
Thanks a bunch, Glen. Keeping my fingers crossed. Loy.
