1929 D crankshaft leaking, flywheel side
Bmklawt
09-14-2006 23:38:39
The crank on my JD D is leaking and getting on the flywheel. I am tired of getting oil on my hands while cranking this.
Is this an easy fix and how do I do it?
Your help is much appreciated.
Bruce
Glen in TX
09-16-2006 07:29:02
 Re: 1929 D crankshaft leaking, flywheel side in reply to Bmklawt, 09-14-2006 23:38:39
29 D crank seal Jas did. The older D didn't use a cork like in later D slinger spacers. If slinger spacer is worn you have to rebuild it or find a better one or NOS one. Gasket sealer can be used on inside of slinger when putting it back on to help. If you make a new one like Jas did then it can be cut for a o-ring.
Glen in TX
09-15-2006 22:27:44
Archives...
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=jd&th=215326
Earl-IL
09-15-2006 10:35:47
Go back to 8-31-06 in Deere forum and take a look at that seal set up. I have used a seal like that on later Deere and has worked very well.Earl
CNESLER
09-15-2006 04:58:48
Bruce
I did my 1952 D last Saturday in about four hours
the hard part is getting the flywheel bolts loose
and setting the flywheel on and off the crank.
Be sure you know the alignment marks on the crank
and flywheel. Also the crank end play is 5 to 10 thousand which is adjusted with the flywheel. I had Dad use a 2x4 wedged against the rear wheel to hold the clutch pully.
CNESLER
