29 D crank seal fix pic for Glen ?
jas
08-31-2006 18:53:53
third party image
This is what I have done to my old 29 that wants to keep throwing oil from the flywheel. To catch anyone up here is the problem.... My 29 has an earlier crankshaft in it. It is the keyed type instead of the spline. Well, the oil slinger is earlier too and it doesn't quite fit the oil slinger housing as it's supposed to. I first looked for the correct 29 slinger but it doesn't fit because the ID is smaller and it wouldn't go over this larger cranshaft. I thought about boring the inside of the slinger but I think that there was too much difference to make it work. So.... I came up with this solution....make a new slinger and bore the housing to accept a lip seal. Hopefully this will fix my problem. I also checked into the correct flywheel and crank, about $250. This was cheap fix for now, maybe if I find an earlier D I would consider a swap later. Just thought I would pass along a few pics so anyone else who has an oil leak problem can do what I did.
jas
09-01-2006 17:33:21
 Re: 29 D crank seal fix pic for Glen ? in reply to jas, 08-31-2006 18:53:53
seal was a cr seal pm37330 from mother deere. Shaft Dia 3.750
Seal OD 4.506
In stock at local JD
Yes there is an o-ring groove with and o-ring in the picture of the new slinger. Don't know the number of that though
Glen in TX
09-01-2006 21:06:06
 Re: 29 D crank seal fix pic for Glen ? in reply to jas, 09-01-2006 17:33:21
Jas, Thanks, Going to save that in my D books.
Glen_in_TX
08-31-2006 23:23:33
Jas, Looks like you came up with a good solution! I knew when you gave me size of the early keyed crank it wasn"t going to work with the later slinger like I had either. Bet it works good for you. Thanks for posting back with the pic. What number seal did you wind up using there?
Earl-IL
08-31-2006 19:37:13
JAS, Looks like you did a nice job on that. Are you going to put sealer on the inside of the new slinger or did you "O" ring the inside? Keep up the good work. Earl In Illinois
