1 Hour on a JD D with Steel wheels
CNESLER
09-03-2006 06:29:36
I got to work the D Saturday for about 1 hour
and the fan bearing failed so I put it back into the shop, as I was backing it into the shop I noticed oil dripping around the flywheel when I took hold of the flywheel to look at the leak I felt that it had a lot of end play. My question is How do I adjust the crank end play?
Thank
CNESLER
Glen in TX
09-03-2006 08:55:37
 Re: 1 Hour on a JD D with Steel wheels in reply to CNESLER, 09-03-2006 06:29:36
third party image
You'll need to loosen the flywheel bolts and then have someone push and hold crank over from clutch side while you push the flywheel in until you have .005-.010" endplay. With a leak that bad you need to pull the flywheel off anyway to replace the seal and check the slinger and cover for wear. Excessive endplay is good about putting more wear on the slinger letting oil leak. You can see in pic what happens when too much play and the groove in slinger gets worn that fits the square headed dowl pin. The square headed dowl pin on crank should fit in square hole on slinger so it rotates with the crank. If pin has sheared off and groove worn you'll need to find a new spacer/slinger or rebuild old one. I forget what year D you are working on now but look down many posts or a page or 2 back and see what Jas did on the slinger spacer on his 29 D machining the cover out and making a new slinger for a lip seal and using a inner o-ring in spacer on crank surface. If your slinger isn't too worn you may get by just pulling flywheel and putting a new cork seal back in with sealer on the crank before slinger goes back on. Have the flywheel and crank splines smooth and clean when putting flywheel back on and don't use oil or grease on splines either or it won't stay tight. Flywheel wrenches shown also if you don't have those.
third party image
Glen in TX
09-03-2006 09:07:46
 Re: 1 Hour on a JD D with Steel wheels in reply to Glen in TX, 09-03-2006 08:55:37
third party image
Jas's fix for his 29 D couple pages back.
