Inserts with power block? 49 G
Ben.So.Tex.
08-08-2006 04:56:02
Would a 49G have inserts or babbits?
This tractor has a power block.
Oppy
08-08-2006 10:08:15
 Re: Inserts with power block? 49 G in reply to Ben.So.Tex., 08-08-2006 04:56:02
Ben,
Are you overhauling the G? I'm neck deep in my G's rebuild. I'm shooting to be ready by November (Devine Pull) but, it depends on the machine shop.
John
Ben.So.Tex.
08-08-2006 12:43:32
 Re: Inserts with power block? 49 G in reply to Oppy, 08-08-2006 10:08:15
John I think it has a bad vavle, so I am just going to rering it and get the head worked on, and get Conrad to rebuild the carb for me since he live down here. Maybe I can give you some competion in Divine. Good Luck with your G Later Ben
Oppy
08-08-2006 14:53:09
 Re: Inserts with power block? 49 G in reply to Ben.So.Tex., 08-08-2006 12:43:32
It's just not right having lost the best JD mechanic is South Texas to retirement. Oh well our loss is your gain! Tell Conrad I said hello.
As for competition, I'm not pulling in Division III, I'm staying in Div. II. You big boys can have that class to yourself.
Ben.So.Tex
08-08-2006 15:12:09
 Re: Inserts with power block? 49 G in reply to Oppy, 08-08-2006 14:53:09
John
I have to pull Div I and II maybe,Don't have the brains or money to build a puller
Oppy
08-08-2006 16:01:07
 Re: Inserts with power block? 49 G in reply to Ben.So.Tex, 08-08-2006 15:12:09
Come on Ben, you're not fooling me! You've got Conrad down there now and two Pollocks can accomplish anything.
Anyway, it was my understanding that a powerblock put you in division III.
Ben.So.Tex.
08-09-2006 04:58:33
 Re: Inserts with power block? 49 G in reply to Oppy, 08-08-2006 16:01:07
1st time I heard of that, later Ben
Oppy
08-09-2006 08:37:34
 Re: Inserts with power block? 49 G in reply to Ben.So.Tex., 08-09-2006 04:58:33
Ben,
You may want to check the latest rules. The set that I have, which are a 2 years old, mention "stock blocks" in Division I and II. The powerblock is an aftermarket block.
I"ve attached a link that discusses the powerblock and where they originated. It"s pretty clear that they are not "stock".
I"m not trying to get you excited about this. I just wanted you to have a heads up as to what could happen.
Again, I haven"t seen the latest set of rules, but I doubt they"ve changes regarding blocks.
John
Duane Larson
08-08-2006 08:32:44
Ben,
It came with babbited rods, but they were often converted to inserts, so about all you can do is have a look-see by pulling the crankcase cover.
