What is a powerblock?
RossMN
10-11-2002 11:05:37
I see alot of people talking about powerblocks and all i can get out of the posts is that they are replacement blocks w/bigger bores i was wondering who made them (m&w, jd, etc) and how much of a hp increase thanks
WTW
10-11-2002 14:27:12
 Re: what is a powerblock? in reply to RossMN, 10-11-2002 11:05:37
Powerblocks were made out east somewhere and sold through Tractor Supply Stores. They replaced the original block with their larger bore block and pistons. The piston bore was increased so much that the pistons are installed and removed from the bottom of the block. The reason for this was the cylinder head end of the Powerblock was kept the original diameter to except the original cylinder head and gasket. There were three different bore sizes of Powerblocks, 5", 6" and 6.5". They made three different 5" bore blocks, three different 6" bore blocks and two different 6.5" bore blocks. The 5" bore block models were the 5-1, 5-2 and the 5-3. The 5-1 was for the 1941-1946 model "B". It replace the original 4.5 inch stock bore. The 5-2 was for the 1947-1952 model "B". It replaced the original 5.6875 stock bore. The 5-1 and 5-2 had the same block and head bolt patterns. The difference was the water manifold patterns and the 5-1 had frame mounting holes in the bottom and side where the 5-2 did not. The 5-3 was for the model 50 tractor and it had a different block bolt pattern and it also had one more head bolt stud in the head pattern, 10 studs verses 9 like the 5-1 and 5-2. It also replaced the original 5.6875 stock bore. The 6" bore block models were the 6-1, 6-2 and the 6-3. They all had different block bolt and water manifold bolt patterns. They did share all the same head bolt patterns. The 6-1 like the 5-1 had frame mounting holes in the bottom and side where the 6-2 did not. The 6-1 was for the 1940-1946 model "A". It replaced the original 5.5 inch stock bore. The 6-2 was for the 1947-1949 model "A". It replaced the original 5.5 stock bore. The 6-3 was for the 1950-1952 model "A" and the model "60". It replaced the original 5.5" stock bore. The 7-1 and 7-2 model blocks were both 6.5" bore blocks. The 7-1 was for the 1942-1952 model "G" and replaced the original 6.125" stock bore. The 7-2 was for the model "70" (GAS) and replaced the original 5.875 stock bore. The 7-2 was a shorter block than the 7-1. It had two more bolt holes in the block mounting flange than the 7-1. The 7-2 also had one more head bolt stud in the head pattern like the 5-3 did. Hope this enogh information!!
Todd
10-11-2002 13:30:23
An aftermarket block that was sold years ago with different style pistons and bigger bore for power increases. Did not not have compression releases. For example: standard A Jd had 5 1/2" bore, An A powerblock had a 6" bore.
John in OH
10-14-2002 10:23:26
 Re: Re: what is a powerblock? in reply to Todd, 10-11-2002 13:30:23
Todd, Are you positive that none of the power blocks had compression releases? Many years ago, my late cousin, the original owner of my '48 G, told me that he had a installed a powerblock on the G. This G block has the compression release petcocks. Is there any method - short of tearing down the engine and measuring the bores - to determine if the block is a powerblock?? Are there unique casting numbers, stampings, or other identifying marks that might give more info?? Thanks, John in OH
Bob
10-15-2002 10:32:38
 Re: Re: Re: what is a powerblock? in reply to John in OH, 10-14-2002 10:23:26
My 6-1 powerblock has "6-1" cast into the top of the block. I suspect you'd find the same on yours. My stock JD A block has a JD part number cast into the bottom of the block. I'd say if you have two numbers with a dash in between cast into the top of the block, you have a powerblock. If you have a JD number cast into the bottom of the block, you don't.
BTW, you don't need to tear down the engine to determine the bore size ... just take off the crankcase cover to see the back end of the block.
