Additional info
Grant Miller
07-19-2006 12:11:43
Thanks for the help so far, I really appreciate it.
I had the clear tubing on the carb to check the float level and it seems to be fine. I left the tubing on when I started the tractor to see what the fuel level would do when it was started and it drops very low. The level is barely high enough to cover the bottom of the bowl when the tractor is running. It seems it's all being sucked into the engine. When the tractor is shut off, the level returns to normal. Would this indicate a large crack somewhere?
John T
07-19-2006 13:10:20
 Re: Additional info in reply to Grant Miller, 07-19-2006 12:11:43
Grant, Im kinda grasping at straws here, hope Duane and Glean or Pat B or others weight in here, but with that being said: IF I DIDNT KNOW BETTER I MIGHT SUSPECT THE NOZZLE HAS DROPPED DOWN INTO THE BOWL AND ISNT BEING HELD UP IN PLACE BY THE BOTTOM CENTER SPRING????? ?? They usually stick n corrode up into place and the spring which holds them up isnt really needed after that?? Was the nozzle removed when you overhauled it and was the bottom center spring reinstalled??? NOTE Im basing this on your indicatign shes running way over rich n black smoking correct????? ?
Anyone else have any ideas or wanna make fun of my guess lol
John T NOT any carb expert whatsoever
Mike M
07-19-2006 13:08:28
Maybe a plugged bowl vent ?
