Grant -- Too many variables here! 1. A very first MUST is clean fuel. If you are trying to use the old gasoline -- gas that has been sitting in that tank all this time of storage, you are asking for grief. Drain it all out, flush the fuel tank and lines with some kerosene or even ordinary mineral spirits - then get all that out. Now install some new gasoline, at least a gallon or two. And now -- place a catch basin under the carb, open the fuel drain cock and look for a nice steady steam! 2. You mentioned a "good" indication when testing float level. Do you mean fuel rose to a point roughly 3/4-inch below the top of the bowl? That, BTW, is the mark to shoot for. 3. An engine in-taking too much fuel is very often a function of restricted air into the carb. DISCONNECT the air inlet elbow at the carb inlet (near the choke). You see, if there is a restriction to air flow into the engine because of dirt daubers in the air stack, opening this joint will provide free air in without having to come through the regular path. If this alleviates the problem, you can look for blockage to the air intake path. 4. Grant, suppose you do the "clean fuel" and the "loosen the air-in elbow" procedures and then repost so we can take you from there. Good Luck - No, Be Blessed. [I forgot -- Luck is for dogs!] (PatB)
