.090 is next
Paul_IN
02-20-2006 13:28:09
It shouldn't be too hard to locate a set of 0.090 inch oversize pistons. You could look for a used set or the usual piston vendors should be able to help you out also. Since there is a good supply of JD B blocks in salvage yards you could try and buy one that is standard bore and then bore it to fit your pistons. Depending on how good a deal you could get on the block it might be cheaper to go this route.
Anthony R. Blanchette
02-21-2006 08:53:01
 Re: .090 is next in reply to Paul_IN, 02-20-2006 13:28:09
Hello, Can you help me to locate a salvage yard to find a John Deere Crawler 2010 Diesel engine?
Thank You,
Anthony
