49 b rebuild
gmc ronnie
02-20-2006 13:13:59
my cylinder is bored .045 already , whats the next size up i could go safely?..050, .055, . 060, ECT ,ECT .also is it worth rebuilding , thanks RON
Dandy Don
02-20-2006 19:17:45
 Re: 49 b rebuild in reply to gmc ronnie, 02-20-2006 13:13:59
Well, if you have no motor how can you be worried about an overbore? You can get .45 .90 .125 pistons for your tractor. B engines aren't hard to find. , and if the tractor was given to you , you're going to come out fine.
At the top of this column in the box that has (A) in it click on the down arrow and then click on B and you find a list of parts to give you a general idea of cost. Don
gmc ronnie
02-21-2006 01:10:59
 Re: 49 b rebuild in reply to Dandy Don, 02-20-2006 19:17:45
i have a block and rods on the tractor, and the cylinder is already bored .045 over and has some scrachts in the walls.
jd b puller
02-22-2006 20:15:57
 Re: 49 b rebuild in reply to gmc ronnie , 02-21-2006 01:10:59
Ronnie, you say it is already bored 0.045 - Does it have pistons in it? You'd be surprised how rough these cylinders can look, yet the engines run fine. I put a D together a while back that easily had 1/8" pits in the cylinder walls. No smoke.
DickD
02-20-2006 15:05:47
I am running a B that is bored .187 and runs fine. It would need a water pump to keep it cool if I used it to work under a load for any length of time.
gmc ronnie
02-20-2006 15:34:15
 Re: 49 b rebuild in reply to DickD, 02-20-2006 15:05:47
is the tractor worth rebuilding or not , i got the tractor for free but has no motor,
Paul_IN
02-20-2006 13:28:09
 .090 is next in reply to gmc ronnie, 02-20-2006 13:13:59
It shouldn't be too hard to locate a set of 0.090 inch oversize pistons. You could look for a used set or the usual piston vendors should be able to help you out also. Since there is a good supply of JD B blocks in salvage yards you could try and buy one that is standard bore and then bore it to fit your pistons. Depending on how good a deal you could get on the block it might be cheaper to go this route.
Anthony R. Blanchette
02-21-2006 08:53:01
 Re: .090 is next in reply to Paul_IN, 02-20-2006 13:28:09
Hello, Can you help me to locate a salvage yard to find a John Deere Crawler 2010 Diesel engine?
Thank You,
Anthony
