Here's a picture, Brandon
F-I-T
02-13-2006 08:01:16
third party image
The "Right Stuff" is what I curious about. I've never used it. The Hi-tack stuff is the reddish, pretty thin, but brushable stuff. I keep a can of that and the regular old Permatex 303 on the bench all the time.
TIMAR
02-13-2006 17:46:29
 Re: Here's a picture, Brandon in reply to F-I-T, 02-13-2006 08:01:16
This stuff works excellent. I use it everywhere you don't need the gasket for shimming or clearance. Not for use around gasoline parts though.
F-I-T
02-14-2006 12:08:57
 Re: Here's a picture, Brandon in reply to TIMAR, 02-13-2006 17:46:29
Not for fuel? Because it dissolves? What about hot engine oil like an oil pan? That's one where I have a problem.
WeirdDeere
02-13-2006 11:21:06
Ohhhh...
I've never seen that "right stuff".
Of course, you could use real Cheese Whiz. It's probably plastic anyway! Ha ha!
Brandon
GPULLER
02-13-2006 13:03:19
 Re: Here's a picture, Brandon in reply to WeirdDeere, 02-13-2006 11:21:06
I use the "Right Stuff" on the block to crankcase on my G and a 70 gas. Had to pull the block off the 70 because of a crack. We had a very hard time breaking the block loose from the crankcase.
I also used it on the inspection plates on the crankcase of my 720 once. (not recommended) I ended up bending the plates before the silicone let loose.
Never had any leaks when using the stuff because its like welding the pieces together! If you never want to take anything apart it works great.
F-I-T
02-13-2006 11:37:25
I hear you there! That might be worth a try....
