Best Gasket Maker
Scarecrow
02-12-2006 19:03:28
I am in the process of restoring a JD tractor and cannot get some of the gaskets. People use different methods, such as making a gasket or using a type of silicone. What is the best thing to use so you won't have those stubborn leaks?
johns48b
02-15-2006 04:54:32
 Re: Best Gasket Maker in reply to Scarecrow, 02-12-2006 19:03:28
in some places gaskets are used like shims in particular around the governor housing so i wouldn't think of not using a gasket there.
Ray
02-13-2006 12:41:00
You can buy gasket material and just make your own.I never had much luck with the sprays or silicone.I would rather do it once and be done than try things that are iffy at best.The automotive industry uses silicone because it's cheaper,faster and one size fits all,not because it seals better.
REDJD
02-13-2006 11:05:23
You might try this web site for hard to find gaskets, has helped me in the past.
www.olsonsgaskets.com
JDBert
02-13-2006 10:30:22
JD used to have a liquid gasket material, it was red and in a squeeze bottle and was about $14. They discontinued it, BUT you can get the same stuff from loc-tite. Works great-stays flexible like silicone and works nice in those spots with rust pitting.
Duane Larson
02-13-2006 06:43:05
I agree with the responses of Glen and Frank, and will add a bit about silicone as a sealer. There are times when dealing with rust-pitted surfaces (which could be smoothed with JBWeld or ...) that it may be convenient to use silicone on a gasket to fill the holes. The trick is to coat the gasket with silicone, put in place, and just LIGHTLY SNUG it up to hold it in place and push the silicone into the holes. Then let the silicone cure for 24 hours before tightening. That will keep the gasket and silicone from moving, and provide a good seal.
Glen in TX
02-12-2006 21:49:36
I'm with Frank on not being much of a silicone fan either. If too much is used it can make those cork gaskets slip out too. The cheese wiz can sealer is okay for some things but it can get old if not used quickly and if old from the store it won't work well either. Otherwise I like using the High tack, Indian head shellac or Aviation sealers from Permatex. I use a piece of cardboard or rubber tile to cut gaskets from the roll material with punches, exacto knife, a cheap plastic circle cutter and another washer gasket cutter from General brand. Sometimes a small ball peen hammer works well too and use bolts to hold the gasket in place while tapping it out but always be careful that small pieces don't fall down in the tractor case.
F-I-T
02-13-2006 07:17:01
 Re: Best Gasket Maker in reply to Glen in TX, 02-12-2006 21:49:36
Glen:
I have never used that product. Is it worth a try? I do have one oil pan that no matter what I do it seems to weep. Doesn't leak a lot, but enough that I keep trying things on it. I thought maybe that orange stuff in a spray can might help fill a gap.
Pan is flat and not bowed, it just seems to have a gap. Anything good out there for gap sealing?
Frank
WeirdDeere
02-13-2006 07:27:53
 Re: Best Gasket Maker in reply to F-I-T, 02-13-2006 07:17:01
The red gasket sealer from NAPA seems be be pretty good, I believe it is the high tack that Glen mentioned.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
F-I-T
02-13-2006 08:01:16
 Here's a picture, Brandon in reply to WeirdDeere, 02-13-2006 07:27:53
third party image
The "Right Stuff" is what I curious about. I've never used it. The Hi-tack stuff is the reddish, pretty thin, but brushable stuff. I keep a can of that and the regular old Permatex 303 on the bench all the time.
TIMAR
02-13-2006 17:46:29
 Re: Here's a picture, Brandon in reply to F-I-T, 02-13-2006 08:01:16
This stuff works excellent. I use it everywhere you don't need the gasket for shimming or clearance. Not for use around gasoline parts though.
F-I-T
02-14-2006 12:08:57
 Re: Here's a picture, Brandon in reply to TIMAR, 02-13-2006 17:46:29
Not for fuel? Because it dissolves? What about hot engine oil like an oil pan? That's one where I have a problem.
WeirdDeere
02-13-2006 11:21:06
Ohhhh...
I've never seen that "right stuff".
Of course, you could use real Cheese Whiz. It's probably plastic anyway! Ha ha!
Brandon
GPULLER
02-13-2006 13:03:19
 Re: Here's a picture, Brandon in reply to WeirdDeere, 02-13-2006 11:21:06
I use the "Right Stuff" on the block to crankcase on my G and a 70 gas. Had to pull the block off the 70 because of a crack. We had a very hard time breaking the block loose from the crankcase.
I also used it on the inspection plates on the crankcase of my 720 once. (not recommended) I ended up bending the plates before the silicone let loose.
Never had any leaks when using the stuff because its like welding the pieces together! If you never want to take anything apart it works great.
F-I-T
02-13-2006 11:37:25
I hear you there! That might be worth a try....
F-I-T
02-13-2006 07:48:55
 Re: Best Gasket Maker in reply to WeirdDeere, 02-13-2006 07:27:53
I thought the Hi-Tack he mentioned was the brushable Permatex in the can. It's reddish. I think the can reads Hi-Tack Aviation sealer?.... I use that to stick gaskets in place. The stuff I was thinking about comes out of an aerosol cheez-whiz can. I thought it was orange.
Glen in TX
02-13-2006 14:41:16
 Re: Best Gasket Maker in reply to F-I-T, 02-13-2006 07:48:55
Hi Frank, Yes, I was talking about the black Right Stuff in the can or tube but had CRS disease when posting before lol. Like GMAN said it does really stick something down well but works well to fill gaps too and seems to cure faster than the other RTVs so it doesn't keep long after opening either. For some reason I like the black silicones when I do use them and always keep some Permatex 598B Ultra Black Hi-Temp or 16B Black Silicone adhesive. Both of those work well for me on gaps and 16B can also insulate electrical to some degree and great for waterproofing some threads. Permatex 80017 Aviation Form a Gasket is the other one with brush in can. It's sticky too but not as sticky as High Tack 98H in can or 996A in aerosol and it's great for holding a gasket like you mentioned. There is another Permatex Super High Tack in a tube and I don't like it at all and it just looks like the yellow weatherstrip glue and caused more leaks for me. Permatex is just what is popular here so that's what I use and there are others like Loctite and all too. Well, let's go fix some flat tires on a fire truck. The fun never ends. At least some snow in forcast for weekend we hope.
F-I-T
02-12-2006 19:14:31
SC:
I do not like silicone sealers (RTV) as it can get stringy and a string can get into gears and block oil passages and such. I have made a lot of gaskets using rolled gasket paper available from NAPA and others. I found a nice set of gasket punches on eBay, and that works out pretty well. Using a good sealant (I like Permatex products) really makes it a more leak-proof seal.
Frank
