DTLX 71 nozzle removal
njs
01-13-2006 09:23:03
Looks like I will have to drill it out. There are 5 diameters that are hidden within the casting... Are there any press fits? Is most of the hidden length in clearance? Do the small nozzle side holes need to be oriented when putting in the new one? Making me nervous!
Thank you.
njs
01-13-2006 15:25:59
 Success Re: DTLX 71 nozzle removal in reply to njs, 01-13-2006 09:23:03
Tapped a 1/4-20 thread in the bottom, inserted a screw nut and washer, jacked it out. Total time, 10 minutes. Thanks guys.
Maark
01-13-2006 12:33:32
I usually use a torch, heat the stem up hot, and throw the carb body in a bucket of water. The stem will almost fall out. Take the small plugs out that way and also the plugs in the bowl that hold the float pin in place.
Mike M
01-13-2006 10:56:48
You shouldn't have to go that far. I use a slide hammer with a screw point that threads in the bottom hole and most pop out. Sometimes heating the casting stem with a torch helps free the really tough ones. You can thread the inside of nozzle and use a small bolt and nut to pull it out also. Some here lay them in the barbeque and heat them up. No need to worry which ways the holes face when replacing it. The nozzles have different dia. but the hole is just one size all the way up until it gets really small where it sticks up through the bore of the carb.
njs
01-13-2006 11:07:21
 Re: DTLX 71 nozzle removal in reply to Mike M, 01-13-2006 10:56:48
Thanks Mike, not nervous now. Now...the barbeque thing was kidding, right?
F-I-T
01-13-2006 11:26:41
 Re: DTLX 71 nozzle removal in reply to njs, 01-13-2006 11:07:21
I do it all the time.
Check this thread:
Duane Larson
01-13-2006 13:09:14
 Re: DTLX 71 nozzle removal in reply to F-I-T, 01-13-2006 11:26:41
Hmmm-- If F-I-T ran a restaurant, I can imagine the menu might include barbequed carb, covered with lye gravy and an order of toasted coils on the side..
As Grandpa Jones used to say - yum-yum
F-I-T
01-13-2006 13:34:58
 Re: DTLX 71 nozzle removal in reply to Duane Larson, 01-13-2006 13:09:14
And "Electrolytic Crumb Cake"!
HA!
RalphinWI
01-13-2006 17:55:22
 Re: DTLX 71 nozzle removal in reply to F-I-T, 01-13-2006 13:34:58
Duane and FIT you just gave me a good laugh. Thanks, I needed that!
njs
01-13-2006 12:31:40
 F-I-T Re: DTLX 71 nozzle removal in reply to F-I-T, 01-13-2006 11:26:41
Well I be!!
Now that I see the date of the thread, I must explain that when searching for info before I post, I get so much unrelated results and it is extremely time consuming. I could be roasting my carb.
