Pat: You probably read from a posting by me that heat soaking a cast iron carb body on charcoals worked well. It sounds like you've never tried it but instantly condemmed the notion. It's been a handy method for me (at least when I can't get access to a stress relief furnace where I can soak up to 1200* if need be), to know that the body has been heated up to at least 600 F*, and if left to cool until the morning, the brass parts will have had a chance to expand and separate from the cast threads without a rapid cooling shock. If you are left with one stubborn plug, that one can be focussed on after a proper whole-body pre-heat. I have also used an isolated propane flame, but not until the entire body has been warmed so as not to promote localized expansion. Any one who has worked with cast iron and heat will tell you that that is a recipe for disaster. I disagree with your statement that "Those plugs are best removed by applying heat directly to the plug, and then a quick cool." The rapid cool down of brass might make you feel good when you hear the sizzle, but it is putting a ton of strain on the junction of the brass in the cast iron threads. The same reason that you are not to add cold water to a hot engine as described in your owners manual should be applied here. Kurt: If you want to try a weld repair on that stem, check out "Muggy-Weld" rod. I have used it for such repairs and it works quite well. Be sure you treat your welding or brazing like you would any other cast work and pre-heat and cool down adequately. If using electric welding, you might want to use a brass or copper dowel up the stem as a locator. It will keep everything true to the stem axis and the weld will not stick to it. Frank
