throttle???
Josh Hoffman
11-25-2005 15:01:45
My tractor has a foot throttle (not hand)...When starting, I have always just pulled the choke, hit the starter & let the choke go, this has always worked fine...should I be giving it some throttle??? I know this is what my manual says, but, I have never done that on this machine before...
Ben48A
11-25-2005 16:38:00
 Re: throttle??? in reply to Josh Hoffman, 11-25-2005 15:01:45
My neighbor has a 3000 gas w/ the 3 cylinder to start it in cold weather you pull the throtle to between 1/4 and1/2 start cranking pull the choke then drop the throttle a little.
G/MAN
11-25-2005 15:41:35
You might have to give it a little "shoe" to get it started. If your plugs are wet, you might be getting TOO much gas, and not enough air to go with it. Try opening the throttle a touch and see if it starts better.
