Fixing DLTX carb stem
Kurt_JDB
11-24-2005 05:31:49
I recently picked up a DLTX-67 carb with a broken stem. Stem is broken just above the threads and the break is very jagged. I would like to try my hand at repairing this stem, and would like some advice on how to proceed. I do not have the piece that broke off.
The carb is not in great condition, and I didn"t pay much for it, so if I screw it up it will be no great loss.
I am thinking I could try brazing a piece of black iron pipe to the bottom of the stem. I have a small maap gas/oxy tourch.
Would appreciate any advice, and information on what is the thread size on the stem.
Kurt
Mike M
11-24-2005 15:28:31
 Re: Fixing DLTX carb stem in reply to Kurt_JDB, 11-24-2005 05:31:49
I can tell you from years of experience working on those carbs. that unless you COMPLETELY disassemble it and clean out all the passages you will have no hope for a successful repair even if the stem repair is a success. Some plugs with buggered up heads you can cut new slots with a small hacksaw,some you just have to drill out. Best to heat with a small tip on a real torch as propane blow torches don't get hot enough quick enough.Heat right on the plug until red hot but don't melt it,then let it cool on it's own then they should come right out. That stem can also be fixed by makeing an adapter and threading the inside of the stem and screwing it in, you have to cut a notch in the threads on the stem end so it lines up with where the fuel comes into the stem and I also cut a spring short to hold the nozzle back up in.Yours may be busted up too far ? Just depends on what tools you have and how good an imagination too as to what will work best.
P Browning
11-24-2005 08:25:44
Kurt -- Take your time & plan your work. Enjoy doing the fix, and you just have to know carb's are becoming more precious each days. It is most liekly well worth saving! The sparkplug idea should work out just fine. Getting the repair installed squarely will be one main challenge, as will be maintaining the "secret passage" across the base end of the stem. Build a small jig to hold the two parts during the bonding part of the operation, and you should be "good to go" as the youngsters say these days. (PatB)
Kurt_JDB
11-24-2005 08:36:55
 Re: Fixing DLTX carb stem in reply to P Browning, 11-24-2005 08:25:44
Pat,
I have heard of this secret passage before, but am not sure where it is. Does it pass above where the nozzel is? What does it do? Can it be accessed from one of the little screws?
Thanks,
Kurt
P Browning
11-24-2005 08:46:57
 Re: Fixing DLTX carb stem in reply to Kurt_JDB, 11-24-2005 08:36:55
Kurt -- If the stem still contains a brass drill plug, the "secret passage" is accessed by removing the plug. Not having viewed your stem, it could be the break includes that region, and if it does, you may need to engage a professional like Robert's Carb to do the fix. They really aren't as expensive as everyone makes out when it comes to doing limited scope repairs such as the one you have. Now, if you have them go on the rebuild the carb -- obviously more cost. (PatB)
DickD
11-24-2005 07:56:12
Kurt; I don't know exactly where your break is, but make sure the hole on the stem right above the threads is clear when finished. Also it is good to remember to drain the carb, if it sets through the winter in an area where the temperature goes below freezing. Failure to do this is what probably caused the break to begin with.
Kurt_JDB
11-24-2005 08:24:30
 Re: Fixing DLTX carb stem in reply to DickD, 11-24-2005 07:56:12
Dick,
The break is pretty jagged, and at one point goes up almost to the step on the stem. I"m not sure what hole you are referring to, if it was in the side of the stem above the threads, the break may be at this hole and I guess I would need to redrill it. Do you know the size and position?
Kurt
Maark
11-24-2005 06:46:33
Use a spark plug. W-18 Champion or it's equivalent. It has the same thread pitch as the original nut. Cut the threads off.Remove the L-shaped electrode. Bevel your end of the carb.You will need to center the threaded piece. Usually a 1/2 inch bolt cut off and inserted into the stem where the nozzle would go. Clamp in a vice or some other means of holding it. You can then Silver Solder or braze your threads in place. Be sure not to braze the threads, but the end that has the 1/8" step to the carb.Just as well to heat the little plugs to remove them easily and clean all the passages while you're at it. Order a nut and gasket from Deere and you're ready to go.
Kurt_JDB
11-24-2005 08:31:37
 Re: Fixing DLTX carb stem in reply to Maark, 11-24-2005 06:46:33
Thanks for the reply. I do want to get the little screws and nozzel out. The screws are all torn up where someone tried to get them out before, and I'm not sure how I am going to get them out. I'm going to try heating the carb on the grill a few times later today after we polish off some turkey.
Kurt
P Browning
11-24-2005 08:41:29
 Re: Fixing DLTX carb stem in reply to Kurt_JDB, 11-24-2005 08:31:37
Kurt -- I realize you may have seen the BBQ idea on this forum, but save your time. Those plugs are best removed by applying heat directly to the plug, and then a quick cool. And if there is anything left to grasp, get a hold of it and back it out. Work them one or two at a time.
A different procedure is needed for the fuel nozzle, and yes -- it defintely needs to come out for cleaning.
As for the size and location of the small "secret passage," It is the size of a # 53 drill bit (.0595" Dia), and located horizontally across the stem -- coming in roughly where the tip of the IDLE adjust needle ends up. It is part of the IDLE path & must be open.
If you want more detail on the JD natural draft carburetors, let me know by going to WWW.JDHPUBS.COM and then contacting me there. (PatB)
F-I-T
11-24-2005 10:34:49
 Re: Fixing DLTX carb stem in reply to P Browning, 11-24-2005 08:41:29
Pat:
You probably read from a posting by me that heat soaking a cast iron carb body on charcoals worked well. It sounds like you've never tried it but instantly condemmed the notion. It's been a handy method for me (at least when I can't get access to a stress relief furnace where I can soak up to 1200* if need be), to know that the body has been heated up to at least 600 F*, and if left to cool until the morning, the brass parts will have had a chance to expand and separate from the cast threads without a rapid cooling shock. If you are left with one stubborn plug, that one can be focussed on after a proper whole-body pre-heat. I have also used an isolated propane flame, but not until the entire body has been warmed so as not to promote localized expansion. Any one who has worked with cast iron and heat will tell you that that is a recipe for disaster.
I disagree with your statement that "Those plugs are best removed by applying heat directly to the plug, and then a quick cool." The rapid cool down of brass might make you feel good when you hear the sizzle, but it is putting a ton of strain on the junction of the brass in the cast iron threads. The same reason that you are not to add cold water to a hot engine as described in your owners manual should be applied here.
Kurt:
If you want to try a weld repair on that stem, check out "Muggy-Weld" rod. I have used it for such repairs and it works quite well. Be sure you treat your welding or brazing like you would any other cast work and pre-heat and cool down adequately. If using electric welding, you might want to use a brass or copper dowel up the stem as a locator. It will keep everything true to the stem axis and the weld will not stick to it.
Frank
Kurt_JDB
11-24-2005 12:51:22
 Re: Fixing DLTX carb stem in reply to F-I-T, 11-24-2005 10:34:49
Frank,
Do you lay the carb body right on top of the coals?
Kurt
F-I-T
11-24-2005 14:36:56
 Re: Fixing DLTX carb stem in reply to Kurt_JDB, 11-24-2005 12:51:22
Yes I do. If you have a pile of coals, you can light them with the carb (de-fueled of course) on the pile so everything warms up together. The ashes that are left in the morning also are rich in phosphates which give them that slick, soapy feel. Any of that stuff that creeps into threads will also help with the separation. If you have to re-heat any of the plugs after the initial heat up/cool down, be sure to wave your propane torch around the carb body until it is hot enough to boil spit, minimum. Then you can safely concentrate on the single plug, heating it until it turns color to a sort of off-green. I like to let them cool down a bit on their own, no water, no air blast. Since they are dissimilar metals they have very different coefficients of expansions, not to mention different specific heats, so as they cool naturally, the two pieces will at some point be two very different sizes. That's when you can remove the plug with the least problem.
Frank
Kurt_JDB
11-25-2005 12:13:59
 Re: Fixing DLTX carb stem in reply to F-I-T, 11-24-2005 14:36:56
Frank,
The grill trick worked real well. After about 4 hours on the grill and a cool down, I was able to turn out all the screw and pull the nozzel. Even though the slots in the screwss were all torn up, I was able to grab them with pliars and twist "em right out.
I noticed a number of plugs in the side of the carb body, (not screws), Two of them plug holes that go into the throat of the carb, across from which appear to be two very tiny holes, and the other is about an 1/8 inch diameter plug near where the economizer plug would be if this was an all-fuel carb.
What are these for, and is there any reason to remove them?
Kurt
P Browning
11-25-2005 13:53:37
 Re: Fixing DLTX carb stem in reply to Kurt_JDB, 11-25-2005 12:13:59
Kurt:
ALRIGHT! "Well Done" (in more ways than one). The two holes that are near the throttle valve are the primary & secondary IDLE orifices. If you visit WWW.JDHPUBS.COM and select Carburetors, you can quickly get up to speed on the basics of JD natural draft carbs. The hole that appears to be 1/8 inch is part of the economizer & bowl vent circuit, and that one will eventually open up all the way back to the air intake side of the carb. That hole may be closer to 3/16" diameter.
F-I-T:
My hat's off to you this afternoon -- I thought you were pulling that guys's leg some time back with the carb on the BBQ trick. 'Hard to challenge success. And as I said above, "Well Done!"
(PatB)
F-I-T
11-25-2005 15:50:44
 Re: Fixing DLTX carb stem in reply to P Browning, 11-25-2005 13:53:37
Well, for me to pull someone's leg over a repair procedure....well that would be "rare".
And...I just like to keep folks guessing....
Glen in TX
11-24-2005 07:30:19
The thread is special and 7/8-18 thread. The spark plug fix is what most people use on it. You can find the taps and dies US or import that size in special thread section at mscdirect.com or mcmaster.com industrial supplies.
