BE CAREFUL
DRL
10-28-2005 18:22:15
If you haven't pulled logs before, take it slow and easy! First off, hook to the tractor ONLY at the draw bar or drawbar support, not on the axle housing, not anywhere above the drawbar. Excellent way to flip the tractor on top of you. Secondly, you need to skid the log so that the butt end is up off the ground. If it drags into the ground, it will not only pull harder, but can catch on a rock, stump, root, etc, and flip the log end for end on top of you. To accomplish this, you have to adjust the length of the chain and where it is placed on the log. Again, not by attaching the chain at a higher point on the tractor. Thirdly, if you are on a hill, you need to be especially careful that you don't get sidewase and turn the tractor over on it's side. Skidding logs can be done easily and safely if proper attention is given, but can become very dangerous if you let your guard down even for a moment.
HoboBob
10-28-2005 19:02:15
 Re: BE CAREFUL in reply to DRL, 10-28-2005 18:22:15
Thanks for the warning.
