Got it going, it was the terminal post.....
DarylJ
10-20-2005 12:21:34
Blksmok, thanks for suggesting the terminal post. It was corroded, which I discovered after bypassing it with the jumper. Cleaned it up, and the pony fired right up. Put the cover back on and it wouldn't start..... so pulled it off and discovered another little item to be careful of.....the clips on the ends of the wires which hook up to the terminal were touching the cover, and shorting out to ground. Carefully straightened them, being careful that they not touch the case, put it together, and it was fine again. Tight quarters inside there, so one has to be careful where the wires/clips are resting.
